What's the best way to seal the injectors to the head?
I just finished pulling the fuel rail for the 2nd time and cleaned the injector holes with carb cleaner and then tool cleaner and also cleaned the injector seals. I re-installed everything and there are still a couple small leaks coming from injectors 1 and 2. WTF. Any tips or tricks? Thanks
Jordan
Jordan
Thank you sir. I just used the soft end of a screwdriver and a rubber mallet to bang in the side...
that is leaky. We'll see if it helped. I also tightened down the bolts that hold the fuel rail down quite well.
I had a leaky injector too. Turned out that the upper o-ring was pinched and deformed slightly when
I was pushing the injector into the fuel rail. Had to replace the o-ring eventualy. HTH...
mill3241
04-17-2016 01:40 PM
|skolnick
10-06-2008 01:18 PM
Jeff Doble
05-01-2003 05:36 AM
nanotech
05-23-2002 05:45 AM
