Who's looking for a CHIP UPGRADE?
Here is APR's thoughts from their web page www.goapr.com about their ECU UPGRADE.
The ultimate chip upgrade for the S4 2.7T engine is available from APR. Expect huge increases in low-end torque, improved throttle response and a smoother, more powerful top end.
The APR S4 2.7T chip is available in a 1.0 Bar configuration. The chip is designed to operate within the turbochargers' efficiency range. Some APR chips are available in an octane specific version for the octane of gasoline that you typically run in your car. The power that the chip makes also depends on which ECU is in your vehicle.
Engine ECU Number 91 Octane Chipped 93 Octane Chipped Notes*
8D0 907 551 A
307hp/366lb-ft 318hp/382lb-ft 2000 6spd
8D0 907 551 B
307hp/366lb-ft 318hp/382lb-ft 2000 Tip
8D0 907 551 H
307hp/366lb-ft 318hp/382lb-ft 2001 6spd
8D0 907 551 M
8D0 907 551 J
307hp/366lb-ft 318hp/382lb-ft 2001 Tip
8D0 907 551 L
8D0 907 551 T 307hp/366lb-ft 318hp/382lb-ft 2002 6spd
8D0 907 551 AA 307hp/366lb-ft 318hp/382lb-ft 2002 Tip
*Due to many variations, ALWAYS refer to the ECU part number in your car.
All APR chip upgrades use encryption, which serve several purposes. First, it keeps prying eyes out of our software and prevents lesser companies from copying the chip and degrading the product. Secondly, the encryption prevents the dealer from flash programming the ECU. Also, all APR software is undetectable to a dealers VAG diagnostic tool.
EMCS
EMCS is available for this car. EMCS is APR's revolutionary patent pending Enhanced Modular Chipping System. EMCS is an industry leading technology that brings many new features to the automotive enthusiast. This technology was developed exclusively by Audi Performance & Racing, LLC and demonstrates APR's continued commitment to lead the industry with the most technologically advanced products available.
Want chipped mode? Want to be able to switch back to your stock settings? Want a race mode to run 100 octane fuel at the track? How about a valet mode that limits power? EMCS is the lone technology on the market that can give you all of these options. No changing of the chip or ECU is required. These programs are available at the touch of a button.
APR has taken your cruise control buttons and utilized them for this function. Your cruise control will continue to function as normal, but will give you the ability to scroll through the programs you have purchased on your APR chipped ECU. The procedure is simple and involves only two steps.
Step 1: Press and hold the "set" button on your cruise control. After approximately five seconds, the "check engine" light on your dash will begin to blink once per second. This will tell you that you are activating program one. This blinking sequence will continue for approximately five seconds.
After this five second interval, the "check engine" light will begin blinking twice per second. This will indicate that you have activated the second program. This process is continued to access any remaining programs you may have purchased. (three blinks = program three, four blinks = program four).
Step 2: Once you have activated the desired program, simply release the "set" button. The "check engine" light will go off, and you will be locked in that program until you change it.
It's that simple.
APR's EMCS is a truly modular system that allows for future enhancements and features to be added as they are developed without the need for additional hardware. EMCS makes the following advanced features possible:
EMCS System
FlipSwitch
Enables you to swap between two or more engine programs on-the-fly using the cruise control stalk. All cars have stock and standard chipped program versions available. Valet, race-gas, and other specialty programs are available for some models.
Fault Code Erase/Throttle Body Alignment (FCE/TBA)
Fault Code Erase allows you to erase and reset engine related trouble codes without having to use a specialty tool. Throttle Body Alignment allows you to manually perform throttle-body adaptation.
Security Lockout
Prevents unauthorized personnel from accessing EMCS functions. The user may select any 1 to 4 digit security code. The security code is entered using the cruise control buttons.
I'll sell my APR CHIP EMCS for 500. all you have to do is send it in to APR and they will soldier the chip to your ecu and you're set. Why pay over a 1000 whey you can get it for 50% off.
(NO ECU included)
8D0 907 551 A
8D0 907 551 B
8D0 907 551 H
8D0 907 551 M
8D0 907 551 J
8D0 907 551 L
EMCS
It's that simple.
EMCS System
FlipSwitch
Security Lockout
(NO ECU included)
X-Pwred225
10
06-02-2004 05:28 PM
kev510
11-09-2003 03:55 PM
AWI S4
19
11-01-2002 09:27 PM
