Will be running K04s with Giac X-chip K03 s/w, questions:
After extensive searching, I gather that I need a 5 bar FPR and MBC to limit boost at high rpm. Fine. Where can I buy an MBC (or what parts do I need to make one)? Also, this goes in where the N75 would be right? Just leave the N75 hooked up electrically, but where is it located in the engine bay? Can I use a vag-com to accrurately tell what boost I'm running to tweak the MBC once it's in?
Info: Will be running Labree split DPs and Neuspeed G2 exhaust. This is a 2000 S4.
Found it, thanks. BUT:
it seems that most of the discussion is for those people with APR, MTM, or Abt chips, which apparently do NOT ignore boost deviations. This results in forcing a serial implementation of the MBC. I, on the other hand, will be running an X-chip, which perhaps could be run with an MBC completely in lieu of the N75?
It's the "Joe P" boost controller I was using...needed to be modified in some...
way (not sure what was done to it, Piggie did it, but it worked great) - I've since removed it and have no need for it since my fueling kit was installed.
If you want it, it's yours.
