X-post: looking for install help w/AWE pedals
<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/752082.phtml">https://forums.audiworld.com/a4gen2/msgs/752082.phtml</a</li></ul>
All I know is that if you like the little plastic nipples on the pedals....
you are going to be disappointed to find out that they will all fall off in short time. My buddy last 90% of his in one week. not worth the money inmy opinion.
they just require a little TLC thats all...
try getting longer machine screws than the ones supplied (hardware store), bolt straight through the back of the pedals and tighten with nuts instead of tapping into the plastic pedals. also, use about 3mm of washers to space the pedal cover from the front of the pedal. this prevents the plastic "nipples" from being pushed out (they only press into place, and if pushed from behind, they will pop out the front) if yu have further problems with the plastic things falling out, glue them inplace.
thxs..I was planning on doing some spacing..the pedals do come with
foam spacer to help reduce the nub loose. I might just use screws like the autovation for the gas, may prove to be the easiest method
My sparcos did the same thing, so I just superglued 2 washers onto the back
of the pedal...problem solved.
<img src="http://pictureposter.audiworld.com/32425/sparco_mod.jpg">
Tgr_Clw
05-18-2006 11:56 AM
Silver Arrow 14
03-03-2003 10:14 PM
