The definitive word on the "throttle lag" issue (hopefully)
#21
Here's the definitive answer
One pertains to the engagement disengagement of the DSG clutch packs when you're at certain RPMs. This happens because within a certain window, the car will begin to upshift of downshift to a different gear if you're off throttle. This will cause disengagement, and if you press the pedal in that gear again, there will be a delay for it to re-engage the clutch packs. Some of this is remedied with how we re-calibrate the torque requests in the S-Tronic transmission software, however it's impossible to remove all of this type of behavior. The second "item of delay" relates to the drive-by-wire throttle mapping on direct injection vehicles. OEMs use certain calibration tricks to tip toe around federal regulations for emissions.
The "2nd item" is more plausible to me. I hope that folks report that the DSG tune eliminates this.
#22
Correct me if I am wrong but turbo lag is effectively reduced power until the turbo spools up and not zero response. The issue I have with my s6 is no throttle response for 1-2 seconds when getting back on the throttle after slowing to say 20km/hr. Its dangerous. When at a complete stop I shift into manual to have some reasonable throttle response otherwise this too is dangerous when pulling into heavy traffic. Come on Audi - this needs attention before someone gets hurt.
#23
For an 'S' car, I find the lack of throttle response not only a safety issue, but it also ruins any fun the car might provide in anything other than a straight line. It is a wonderful GT car, great for soaking up the miles and commuting to and from work. Throw in a 90 degree corner though and the car is just an embarrassment to the 'S' car heritage.
If I don't get an acknowledgment from Audi and recall or fix by late Spring I've decided to sell and purchase something else.
I've learned my lesson when it comes to buying cars without long extensive test drives. I'll never buy another vehicle without putting the vehicle through a rigorous trial. With the S6, I only had a short drive before I placed the order. I won't make this mistake again.
#24
Too bad, that would have been an easy $15 fix.
#25
Hello, my car is now on 80.000 km's
I had the problem from day one.
Yesterday i got a new mechatronic unit (part of the s-tronic gearbox) (warranty) the problem of a delayed gas response and jerky drive from stop is 100% solved !!!!
It feels like i'm driving a new car.
#26
Interesting...I found another guy who had the Mechatronic unit replaced on his B8 S4 to address some jerkiness and clunking. Something tells me this will be tough to get AoA to cover under warranty. I have my 15k next week; I may ask about it again.
#27
That's a lot of miles/km. Is your car a 2013 C7 S6?
#28
#30
The miles add up when you are having a good time driving your car.
