Spacers for 2013 S6 on stock 20" wheels
Hey all. Can anyone confirm for me success running 12mm front and 15mm rear spacers with the stock 20" wheels on a 2013 S6? The posts I found indicated that others were using those sizes, but I wasn't 100% that it was with the 20" wheels and not the 19s. Any advice appreciated.
Thanks!
GregW
2013 Estoril Blue S6
Thanks!
GregW
Thanks!
GregW
Thanks!
GregW
This should help
Thread from another member that ran the same setup.
https://www.audiworld.com/forums/sho....php?t=2846326
Which spacers did you buy? It looks like there are 2 types of 15mm spacers on the Achtuning website. Also, what lugs are needed for the 12 and 15mm spacers? Sorry for the noob questions, but I've never run spacers before and would like to add these.
Thanks guys. Hopefully they'll fit.
For those who asked, I ordered through Achtuning. They were very helpful by email, but hadn't installed any spacers on S6s so couldn't advice on specific fitments. They suggested getting a set of 15s and doing a test fit on the front to see if I wanted to go 15/20 or 12/15, but I ended up just ordering the 12/15 set.
This is my order info from Achtuning:
H&R 14mm diameter lug bolts for Audi (sold in sets of 10 lugs)
Seat, head, diameter and length: 14x1.5x40 R13 Ball Seat (H&R # 1454003) 1454003 1 $44.50 $44.50
Seat, head, diameter and length: 14x1.5x43 R13 Ball Seat (H&R # 1454303) 1454303 1 $44.50 $44.50
H&R 3055668 5x112 66mm CB 15mm wheel spacers (pair) for Audi 3055668 1 $76.96 $76.96
H&R 2455668 5x112 66mm CB 12mm wheel spacers (pair) for Audi 2455668 1 $76.96 $76.96
I'm not vouching that this setup will work for any else's car (or even mine for that matter since I don't have them on yet), so take it for what it's worth, which isn't much since I'm a n00b at this myself. If anyone sees any obvious errors in the order, I'd appreciate a heads-up though.
I called AWE tuning and they set me up with the proper spacers and lug nuts from H&R.
Spacers have the effect of lowering the spring rate, everything else being unchanged. It may in some cars affect steering geometry enough to throw off factory preset stability control parameters.
