Wheels & tires
#11
#12
My winter wheel set is:
Part Number: 4G0-071-499-D -8Z8Diameter: 19"Size: 235/45 R19 99V XL
(audiwinter.ca)
The narrower tire works better in snow. The tires I got - ContiWinterContact™ TS 830 P seems to handle really nice and are actually quieter than the summer performance Pirellis I got with the car. I would easily recommend that setup.
(audiwinter.ca)
#13
Thanks!
Thanks to all who replied!
I just received Konig Interform IF89512326 rims (19x8.5, 32mm offset), hub centering rings and a set of bolts.
https://konigwheels.com/wheels/flow-...els/interform/
Considering Michelin X-ICE 245/40R19:
https://www.tirerack.com/tires/tires...=WinterSection
#14
Need some opinions
2018 S6, 20" Black Optics with the summers still on. Located in North Jersey.
I travel for a living and work from home when I don't. No commuting. Most likely I will not need to take the car out during or after a snow storm (we have another car) and am aware of the reduced grip at or below freezing temps. Will I be OK through a NJ/ NY winter with leaving the summers on? Or is it really that unsafe running around with summers on below freezing?
Any advice will be appreciated.
#15
Don't use summer tires in cold weather!
Even when there is no snow or ice, just a dry cold day, you (and I, in Upstate NY) will be driving on hockey pucks. Summer tires are rock hard at below 40F, and can't guarantee safe handling.
#16
I am in central NJ. I think its unsafe to leave the summer tires on when it gets below freezing. Actually, they start to turn to stone below 40 deg F, provide little grip and would be a disaster on ice or light snow. I recommend winter tires - I use Michelin Artic Alpin PA4, which rides most similar to summer tires. Or you could just buy all season tires and use the year round. There are a few good choices. I have an extra set of wheels with the winter tires. I would be amazed if you don't bend a wheel on a pothole - it doesn't take much. While the dealer ordered a wheel, I was able to use a wheel from my other set of tires. Very handy.
#17
I don't know about below freezing temperatures. Take it out on a dry day and see for yourself. Find an empty parking lot and try a few hard stops and tight turns.
#18
On an M3 I had previously, I ran Continental summer tires year round including winter temps in the 20s. I had another car to use when there was snow/ice/slush on the ground and I would never advise using summer tires in those conditions. I thought the car was fine on summer tires in cold and dry conditions as long as you don't push it to 100%. The thing is - even if you get dedicated winter tires you're not going to go all out anyway since they're not made for handling and can get really squirmy.
#19
Thank you for all your replies
Noticed the car rides a little harsher when it's colder but didn't realize summers will stiffen as much as you guys describe.
I do want to have this beast an all weather beast so went ahead and ordered Contis Extremecontact DWS (all seasons) from Tire Rack and have an appointment at dealer to have them installed Monday.
Thanks again!
Thanks again!
#20
Thanks again!
Thanks again!
