Any way to disable adaptive light warning?
Old 08-28-2015, 09:38 AM
CWTech's Avatar
Default Any way to disable adaptive light warning?
I know it's been mentioned before that perhaps pulling their fuse, but does anyone have experience getting rid of the adaptive headlight warning besides replacing/repairing the headlight?
I did try pulling the fuses indicated in the panel, but the warning and alert still pops up whenever the car is started.
Audiv10 (11-23-2021)
Old 08-28-2015, 11:47 AM
the_duke's Avatar
What is wrong with the lights? Best way to disable them is to fix them. you could code them out in VCDS but i'm not sure what will happen.
Old 08-28-2015, 03:09 PM
Necromancer
ScottCNelson's Avatar
Default No, There is No Way to Disable
Unfortunately, there is no way to disable the warning. I fought this for a long time on my passenger side. There are three things that can go wrong:
1. The control module. Can DIY with some difficulty. Cost 1K at dealer, about $345 OEM NEW. They are known to fail due to water intrusion.
Power module for cornering light for 2008 Audi S8. #4F0941329D
2. The Sealed headlight. The curve motor and sensor are in the sealed beam and can not be replaced individually. Very costly at dealer, like $2K, used 500-600 and will require removal of front bumper cover. Not cheap or easy.
3. The connector. There is a 14 pin connector at the lower back of the headlight (B!tch to get at!). Interestingly, it's a male connector with female tines inside that loosen up over time (known issue). Disconnect and use a pick to gently pry them back together. This worked for me and $0! Alternately, the entire connector costs $15, but will need special tools-skill to replace or soldering skills. I found the info about this on ROSS, about the Passat which uses much of the same tech as AUDI, and certainly the same connector:
02628 - Ross-Tech Wiki
Chinese connector with pigtail:
http://www.ebay.com/itm/251897886628?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
OEM Connector:
HOUSING | Genuine Volkswagen | 1J0-973-737
Old 08-28-2015, 06:46 PM
CobraCommander's Avatar
New Headlamp Front Lamps Connector 14PIN for VW Golf MK6 1J0973737 | eBay
OEM Connector:
Good info here!
Old 09-02-2015, 09:08 AM
carl viking's Avatar
Default Excellent
OEM Connector:
This is a fantastic post - will save numerous people a lot of time and headache!
Old 10-15-2015, 07:47 AM
Slappy Rimshuck's Avatar
Default Symptoms?
Great post. Can you or anyone else on this thread tell me what symptoms they experienced to help diagnose the problem? I have the warning message flashing constantly, but don't know where to start. The lights are all on as normal when stationary and I haven't driven at night for a while to notice anything unusual with the adaptive pointing.
OEM Connector:
Old 10-15-2015, 08:38 AM
MP4.2+6.0's Avatar
Starting point is to pull codes with VCDS. That will get to basics like is it in a specific headlight unit, is it the steering sensor, etc.
Old 10-15-2015, 06:51 PM
Necromancer
Default Pul the Codes
Agreed. Of course, the symptom besides the MIL is the curve light not working on one or both sides. Here's the data I pulled with VAG-COM:
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Shop #: WSC 41776 001 1048576
VCID: 295904A98012A656EC9-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH02 0010
1 Fault Found:
02628 - Sensor for Swivel Module Position; Right
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 110168 km
Time Indication: 0
Date: 2015.02.17
Time: 18:20:07
Old 10-16-2015, 04:32 AM
SS_RTR's Avatar
I also started getting the defective message on my 2007 A8. Mine appears to be the driver's headlight cornering motor. Up/down tests work, but motor won't swivel side to side when I run test in VCDS. I'm not looking forward to dealing with that bumper or possibly ordering a new $1100 light but in my case, as I understand it from some of the other threads, the motor itself isn't replaceable, although some of the parts diagrams online appear to show the motor part# in the part diagrams.
Hopefully your fix is a less expensive solution.
Here is my scan:
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Coding: 0000018
Shop #: WSC 02313 785 00200
VCID: 2959D8A180EC94762A-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
02627 - Dynamic Cornering Light Motor; Left (V318)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 35
Reset counter: 199
Mileage: 157624 km
Time Indication: 0
Date: 2015.10.05
Time: 19:44:40
Old 10-16-2015, 06:31 AM
Mister Bally's Avatar
I've posted regarding this before, but on a MY 2004 that does not corner, only adjusts with the suspension height. When I had the error it only occurred when it was damp or had rained. It turned out I did not properly close the access cover after replacing the Xenon lamp. Once it dried our in a few days, all was well until it rained again.
I used a hair dryer to dry the interior our and then properly closed the cover and all has been well since. Net cost was my time.
Quick Reply: Any way to disable adaptive light warning?
