Bluetooth Telephone Issue
Sorry to make a new thread, but I successfully got my bluetooth module working. However there are a few unique issues. The first thing I noticed was that, when receiving a call there is not audible ringing, letting you know someone is calling, and once you answer the call I could not hear them but they could hear me. The second issue is once a call, that was placed or received is over the music from radio/ami/cd will not resume and the AMI displays, which can not be unpaused:
The only way to get the audio to resume is to reset the MMI. I am currently updated to 46.1.0 on the MMI, however my bluetooth module is currently:
or
which ever helps best identify the SW level. Now that I think of it. Whenever I updated my MMI system I didn't have the bluetooth telephone installed. Are the issues described above why there is a special bluetooth disc included with the 46.1.0 update? Do I need to rerun the 46.1.0 update now that I have the BT telephone installed or just run the bluetooth disc? Any opinions will be helpful, I am quite honestly surprised that I got the BT to work this much so far.
or
HTML Code:
-------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 77: Telephone Control Module Part Number: 4F0 910 336 H Component and/or Version: Handyvorb2 H16 1130 Software Coding: 0010970 Work Shop Code: WSC 00000 VCID: 285FA0A09BBC3C0181-807C Advanced Identification Serial number: 00000007566439 Identification: JTB-074 Revision: 00000000 Date: 27.02.07 Test stand number: 0000 Manufacturer number: 0098 Software XCR_???????? XDSP_1130 XST7_1.18 MMN_010911 MTP20_2.04.02 Misc. Hardware number: 4E0 862 335 VCDS Info: VCID: 285FA0A09BBC3C0181-807C Labels: 4E0-910-336.lbl
The sequence of MMI 4610 followed by BT install could be your problem. No telling what software versions are loaded onto the BT module and if they are pre-4610, that could explain your issues. I would try running the Bluetooth disc first - if it will load by itself - otherwise I would rerun the 4610 update.
Alex Srbljan
10-06-2016 07:09 AM
Boulder
04-05-2002 09:30 PM
hetzer
11-05-2001 06:57 PM
