Audi A8 D3 steering column
Old 07-20-2017, 02:15 PM
ESTMan's Avatar
Default Audi A8 D3 steering column
Hi all.
I have problem with my steering column. The buttons where changed by the laa owner and still didnt work. Well sometimes did and then didnt. Know its all shut down. No movement. And vcds show only 1 fault. What to look for 2 fix it?
Old 07-23-2017, 02:20 PM
Jack88's Avatar
Could be a bad connection, wires could have been damaged in the column, or it could be bad buttons.
Old 07-23-2017, 04:15 PM
TSHong's Avatar
Have you tried the adaptation. That is always the first thing you do in repairing this type of issue.
Old 07-23-2017, 07:28 PM
ESTMan's Avatar
Yes i did the basic settings adaption. It goes in and out but not up and down. Just with the buttons it doesnt do nothing :/
Old 07-24-2017, 03:18 PM
Jack88's Avatar
Does going through the different presets move it up or down?
Old 07-25-2017, 07:55 PM
ESTMan's Avatar
What do you mean? How can i check it?
When i do the so called factory reset then in and out. In between in makes a clicking noise like it cant go up and down. There is the code 01 but if i change it 02 then it show some error.
Even after i do the factory reset it wont let me move it with the buttons.
Old 07-25-2017, 08:15 PM
Jack88's Avatar
When I say presets, I refer to the memory seating positions. Steering wheel position is included in that. I also believe the small button behind the adjustment **** controls the function that moves the steering wheel out of the way when you go to get out of the car. If with neither of these the steering wheel moves up or down, I suspect either a fault with the column motor or wiring. If they do move it, then the switch on the column is suspect.
Old 07-26-2017, 01:00 AM
ESTMan's Avatar
Okey. now i understand what u mean. well previous owner told me he changed the buttons and it helped a liddle but eventualy it stoped working. when i leave the car the column wont move in eather position the switch is. i can't even move it myself. i think i try new buttons from another D3 and if it wont help then i think new column is needed.
if it needs replacement , is it difficult 2 do it myself? havent done thats sort of thing before.
btw ty for youre help
storka
20
10-25-2015 10:45 PM
ESTMan
Telematics Discussion
04-20-2015 06:08 AM
Buzz1138
10-14-2005 02:57 PM
bison
03-10-2005 11:26 AM
wcheung
08-22-2002 08:33 AM
Quick Reply: Audi A8 D3 steering column
