MMI Oil Level Meter
MMI Oil Level Meter
Hey folks,
Something sort of new I am dealing with - I searched but did not find anything. Over the last few months - The oil meter in MMI is not reporting levels. I get the standard wait 2 mins and then shut the car off and such. It never does respond. The last time it did this for awhile, I reset the MMI and then shortly after it started reporting. It worked after that. I just changed the oil or had service done last Friday and so far it has not reported once - just the message is appearing. I have reset the MMI again multiple times. Does that system take a bit to respond after any oil adds or changes?
Does anyone have any ideas? IS something related to that system failing or is a sending unit going / gone bad? Are there any tricks to get the system to re-initialize correctly? I have no problem getting a stick and doing it that way, but I like things working on the car.
I have a 2012 3.0T Prestige 65K miles.
Thanks for any help you all can provide!
Hey folks,
Silver, the car has to accumulate some miles before the oil level will display after the hood has been opened.
I've found a variation on what is mentioned by 537:
Key on (engine not running)
Open the hood
Open the driver's door
Check the oil level MMI display after a minute or two and you should get a reading
Open the hood
The process from my dealer and owner’s manual is as follows:
• Run/drive car until it reaches operating temperature
• Stop, then turn engine off
• Turn the ignition only back on
• Wait 2 minutes
• Then select car, systems, service, etc. to see the oil level
Doing things in this order, the function has always worked for me.
• Wait 2 minutes
you guys were right on!
After my commute yesterday I parked at work and shut the engine off - waited and BOOM there is the meter. I am thinking after the hood / oil-change from service and such....it just takes awhile for that system to report and function (As you all stated...) now I know and won't get bummed!
thanks again
thanks again
thanks again
thanks again
I can actually answer that - there is either a camera or a sensor that measures the geometry of the wheel and the bulge at the tires contact with the street - anywayz the way I understand it - the camera monitors the shape of the tire and if there is a change that is outside of tolerances, then the system triggers a warning.
I think Snag once a while ago described how it worked - that's what I remember about it.
not 100 percent confidant with my response, but darn near.
This makes no logical sense. A TPMS RF Sensor doesn't cost very much, and the radio to receive the signals, likewise. A four camera system with computer code, and computer to run it, would cost much more. It would also have to be kept clean, in a wheel well. I don't buy it.
