2012 Q7 3.0T Starts and then dies
I saw that behavior in my 2011 - i know this sounds stupid, but is the fuel below 1/4 of a tank?
Seems like whatever you did, it fixed it, but more details about what "part" you installed would help.
Thanks for the feedback arU4ic. The part I replaced was the temperature and pressure sensor: . It didn't solve the problem. I'll pay attention to the gasoline fill level to see if it is only when below 1/4 of a tank.
Thanks for the feedback arU4ic. The part I replaced was the temperature and pressure sensor: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 . It didn't solve the problem. I'll pay attention to the gasoline fill level to see if it is only when below 1/4 of a tank.
Thanks for the help and advice. I ended up taking it to the dealer because the problem continued to worsen. It turned out to be the high pressure fuel pump. Cost to replace was $700, and well worth it, it is running great now.
Derek Brown (08-03-2019)
Monte, My Q7 is doing the exact same thing. Can you get the P/N for the pump from the receipt or any codes that came up? Thank you
Monte. Thanks for posting my car has exact same issue Just want to verify so i dont buy the wrong part. Did you have the mechanical pump on the engine replaced. Or the one inside the gas tank?
Going to bump this thread instead of starting a new thread. My 2013 is doing the exact same thing, It will die each time i try to start unless I give it a lot of gas, then it cranks up and runs. Anyone else ran into this problem and resolved it with replacing the pump?
I had this same issue with our old 2007 Q7 with the 4.2 V8. The left side HPFP failed both mechanically and electrically, resulting in a ton of fault codes, I chased my tail for days. The engine would start, but idled very rough, had no power, etc.
Tim Baker
13
03-14-2023 03:20 PM
geordie
02-26-2008 05:17 AM
SCL
Audi Original "S" Cars
26
12-17-2006 07:12 PM
BlueS4orce
08-29-2003 02:50 PM
