Sport differentials retrofit
Old 09-24-2017, 07:51 PM
qqq1970's Avatar
Default Sport differentials retrofit
Hown easy to retrofit sport differentials in A6? What else is needed besides the diff? Vag programming required?
Old 09-25-2017, 06:53 AM
Nakedhoof's Avatar
You'll also likely need a module, or two.
Old 09-25-2017, 10:06 AM
superswiss's Avatar
You'll be better off upgrading to the S6 if you want the sport differential. The A6 does not have the sport differential as an option from the factory, so it'll probably require a custom tuner to get it integrated. The sport differential is part of the ESP, so the A6 most likely doesn't have the software to control the sport differential in the first place. Simple coding won't do it. Besides, based on folks who had to replace a failed sport differential have reported that the cost is close to $10,000 USD, so between the parts, labor and custom development to retrofit one to an A6, which doesn't have provision for it in the first place, you'll probably look at a similar or higher price tag.
Old 09-25-2017, 11:28 AM
peri77's Avatar
In Europe the sport diff is an available option for A6 also. So the SW must be out there ...
Old 09-25-2017, 12:13 PM
DanfZX14's Avatar
The 2017 A6 3.0T Competition model also adds a rear sport differential that was previously only offered on the S6
Old 09-25-2017, 01:05 PM
superswiss's Avatar
Early on and pre-FL it was at one point, but no longer is and never was on the FL A6 afaik. So I guess the model year might be a factor to consider for a possible retrofit.
Old 09-25-2017, 03:51 PM
qqq1970's Avatar
Mine is MY2012 and I read rear sport diff is available as option / std for 3.0T in some markets. That's why I asked.
Old 09-25-2017, 06:23 PM
superswiss's Avatar
Looks like I looked in the wrong place. The sport differential is indeed still available for the A6 in Europe, so perhaps it's technically possible to retrofit on a U.S./Canada spec model with coding. However, the 3.0T with Tiptronic is a North America option only. In Europe the 3.0T doesn't exist anymore, only the 3.0TDI. Don't remember if it existed for MY2012. The A6 for North America has always been a bit different. In Europe most trims are offered with the S-tronic, whereas North America got the Tiptronic instead. Not sure what that means as far as coding and provision for the sport differential is concerned.
Old 09-25-2017, 09:46 PM
peri77's Avatar
3.0T is not available anymore on audi.de, this is a surprise for me. The last models are from 2016 :
https://suchen.mobile.de/fahrzeuge/s...der=DESCENDING
In Europe it was equipped with the 7 speed s-tronic (double clutch transmission). Here only the BiTurbo TDI comes with the 8 speed ZF automatic transmission all other C7 is equipped with the s-tronic.
Old 09-26-2017, 02:55 AM
morski's Avatar
New diff, new module, specific wiring such as flexray, new esp unit and trial and error coding to get it to work.
johnnyboy4.2
24
01-20-2008 01:28 PM
saversc
10-25-2004 07:10 PM
Ken-Arild Kristiansen
06-14-2002 03:57 PM
Ballard2.7T
11-17-2001 08:37 PM
A6intel
06-20-2001 05:28 PM
Quick Reply: Sport differentials retrofit
