Multiple Misfire After Changing the Aux Water Pump
Old 10-15-2017, 11:09 PM
ChrisMitchell's Avatar
Default Multiple Misfire After Changing the Aux Water Pump
2000 a6 2.7
I just changed the Auxiliary water pump, so I had to take the intake manifold off. And after putting everything back together I had multiple misfire code. And actually the car lost power while driving and started shaking. Its all good though, got a tow and it still drives.
Bolts are tight.
Spark plugs are good.
coils should be fine but I can try changing them.
Cannot think of anything else though, and this started immediately after the job, so I really dont think coils will do it.
Any ideas?
Old 10-16-2017, 04:20 AM
georgeb944's Avatar
Probably a vacuum leak due to a misaligned intake manifold gasket.
If you can, do a boost leak test (google for DIY boost leak tester) or smoke test (if you have that available.
Of course, it could be an electrical connection that you have missed, etc.
Old 10-16-2017, 03:26 PM
Thanks a lot. If I need to realign the manifold do I need new gaskets?
Old 10-17-2017, 03:07 AM
georgeb944's Avatar
If the gaskets are damaged, then, yes, you will need new gaskets.
The purpose of the gasket is to completely seal the intake manifold from air leakage into or out of the area. If the gasket is bent, torn, rippled, or otherwise damaged, it will not do its job.
jseklund
05-20-2013 03:10 PM
zarati
12v V6 Discussion
07-29-2009 08:50 PM
ColoradoBrad
11
12-19-2007 07:30 AM
wisconsin_quat
10-31-2007 07:08 PM
HdiaS4
14
08-21-2007 02:08 AM
Quick Reply: Multiple Misfire After Changing the Aux Water Pump
