AZE in HUD A4 B9
Old 11-05-2017, 08:51 AM
TurboMad's Avatar
Default AZE in HUD A4 B9
Hello,
I'm a new member and I have coded traffic sign recognition in my A4 B9 with VAG CAN PRO and it's working perfect, I can't find anywhere the coding for getting it showing in the HUD.
Thanks in advance for your help
Old 11-05-2017, 09:19 AM
munsabin's Avatar
It's so much easier to understand what someone's talking about when it's not all acronyms. Too many freaking acronyms.
Old 11-05-2017, 09:28 AM
TurboMad's Avatar
Sorry for this, I have coded "Traffic Sign Recognition" in "Virtual Cockpit" and it's not showing in the "Head-Up Display", and I cannot find the coding for this anywhere.....
Thanks
Old 11-05-2017, 11:02 AM
gguy's Avatar
Thanks
How did you code it in in the first place? No HUD here, I’d just like to code in traffic sign recognition but I thought it could not be done.
Old 11-07-2017, 04:01 AM
TurboMad's Avatar
Hi gguy,
You need to have VCDS from Ross-Tech or VAG CAN from VagTech or OBDEleven and of cause the front camera for Audi Pre Sense, I don't if this standard equipment in the US....
Coding:
STG 5F (Informationseletronics)
STG adaptation
Vehicle function list
Select BAP-traffic_sign_recognition_0x21 -> adjust value to active
Select Vehicle Menu Operation-menu_display_road_sign_identification -> Adjust value to enabled
Select Vehicle Menu Operation-menu_display_road_sign_identification_over_thresho ld_high -> adjust value to enabled
STG A5 (Front/Camera)
STG access authorization
Enter security code 20103
STG Long Coding
Byte 1 -> enable bit 0
Note: For newer cameras, this applies instead: Byte 16 -> Bit 4
STG 17 (dash panel insert)
STG Long Coding
Byte 5 --> Enable Bit 2
ENJOY !!
Old 11-07-2017, 08:02 AM
nadddd's Avatar
Which location / market are you in? Maybe this coding only works for some countries.
Old 11-07-2017, 10:44 AM
TurboMad's Avatar
I'm in France...this is working in my A4 2.0 TFSI Quatro from 2016, you need the front camera in windscrren mirror (STG A5 Front Camera) this is standard equipment in Europe I don't know about US....
Old 11-17-2017, 03:41 AM
nadddd's Avatar
Sorry I won’t be able to help with getting VZE on HUD.
The US cars doesn’t seem to be able to get this work work. But I have a ROW car and keen to find out if this works. Do you mind sharing your A5 module Long code and adaptions?
Did you change byte 1 or 16?
Old 11-20-2017, 12:05 AM
TurboMad's Avatar
Here you go.....
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 8W0 907 217 A HW: 8W0 907 217
Component: BVS H14 0030
Coding: 0404090200000403022023A2C50000FC00F0C020C000
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 3A70B9A9BD125C9684-806E
Old 05-21-2018, 11:36 PM
sergey307's Avatar
Here you go.....
Could you please share also 5F module - long coding and adaptations?
Thanks in advance!
Quick Reply: AZE in HUD A4 B9
