Q5/SQ5 MKII Discussion Discussion forum for the Second Generation Audi Q5 SUV
OBD Eleven
Old 11-19-2018, 04:55 AM
116Crew's Avatar
Default OBD Eleven
Hello All!
I just learned about OBD Eleven and I wanted to get input from everyone and what it can do for the Q5.
List some of the things you did with the OBD Eleven.
Thanks!
Old 11-19-2018, 05:03 AM
gqllc007's Avatar
https://www.audiworld.com/forums/q7-...leven-2906323/
Old 11-19-2018, 05:41 AM
rbreeze's Avatar
https://www.audiworld.com/forums/q5-.../#post25067328
Old 11-19-2018, 06:53 AM
116Crew's Avatar
RThank you all!
Thats a lot of reading so let me just confirm.
1. Could I turn on ALA? Will it work with my Premium Plus? Or would I need additional hardware that my car doesn’t have?
2. Could I disable VIM?
3. Anyway to have the movie play directly into virtual cockpit?
4. Parking system plus with top view camera system?
thanks!
Old 11-19-2018, 07:22 AM
rbreeze's Avatar
Originally Posted by 116Crew
Thank you all!
1. Could I turn in the ALA? Will it work with my Premium Plus? I would need additional hardware that my car doesn’t have?
2. Could I dusable VIM?
3. Anyway to have the movie play directly into virtual card bu anyway to have them movie play directly into the virtual cockpit?
thanks!
^ I assume you have a 2018 Q5. With that said, note the following....
1. The 2018 Q5 Premium and Premium Plus (USA models) come with Audi Pre Sense City, so yes, you can turn on ALA. No additional hardware is needed.
2. You can apparently enable VIM with the OBDeleven, but only if the vehicle has early version (pre-1116) MMI firmware. The OBDeleven mini-app to enable VIM does not work on models with firmware version 1116 and newer.
3. I don't understand the first part of your question re virtual card (?). As for the 2nd part, you cannot display movies on the virtual cockpit display - movies can only be displayed on the main MMI Infotainment display.
- Richard
Old 11-19-2018, 07:37 AM
116Crew's Avatar
- Richard
1. Yes, it is a 2018 Q5 Premium Plus and has Pre Sense. Will I then have the config menu in the MMI? Or will there be any additional config to do?
2. Ok, ty
3. I saw it in the VC of a TT where it played the video in the VC.
4. What about the Parking system plus with top view camera system?
Old 11-19-2018, 08:16 AM
BFN949's Avatar
I would be awesome to turn that on, I've not seen that done. Remember, on the TT the VC is the only/main display. There is no centre display as is the case with the Q5.
Old 11-19-2018, 08:26 AM
ribeye's Avatar
Any recommendations on which one (Brand or model) to purchase? I am thinking of getting one myself.
Old 11-19-2018, 08:43 AM
rbreeze's Avatar
2. Ok, ty
1. Yes, you will then have the config menu in the MMI. Enabling ALA using OBDeleven is a 2-step (2 mini-app) process. There is no additional config to do.
2. yw
3. As my good friend BFN949 mentioned above, the TT is an entirely different animal, having the VC as the only/main display.
4. Your Q5 Premium Plus already has Parking system plus, and the Top view camera system (which comes only on the Prestige model) requires hardware (2 additional cameras) your Q5 doesn't have. It's not possible to turn this feature on with coding without the necessary hardware on board.
Old 11-19-2018, 09:09 AM
116Crew's Avatar
2. yw
thank you! One last question how safe is it using this especially if I’m leasing the car.
Quick Reply: OBD Eleven
