Steering Wheel Angle Sensor
I’m looking to add ALA to my vehicle along with adding the correct stalk switch. I have most everything figured out except for the steering wheel angle sensor. Apparently it needs to be calibrated after being installed. Has anyone had this done and if so, what was involved? It looks like a trip to the dealer is needed. Wondering if they would do it, cost, and any effect on warranty.
Thanks,
David
Thanks,
David
Thanks,
David
Thanks,
David
You dont need to calibrate anything for the steering wheel. All you are doing is resetting the angle sensor using a Basic Setting. For 650, I had bought the heated wheel, steering stalks and VCDS, and had money spare.
If you just want a half-*** job, then yeah a VCDS at your own garage can do that, but you'll never know if your wheels are pointing straight.
Folks, this is just to get the new switch calibrated, not the cameras, not a wheel alignment, just the turn signal stalk. Nothing else is involved.
VCDS will just allow you to reset the new stalks to the same angle the previous one was at. No better or worse. It assumes the previous angle was correct. Hence why this is called a Basic Setting, not a calibration.
mark-bunak
A4 (B9 Platform) Discussion
10-20-2021 05:11 AM
bruce_miranda
A4 allroad (B9 Platform) Discussion
11
03-20-2021 12:28 PM
SmokinS4™
14
02-13-2007 03:59 PM
Mike@VAST
08-16-2001 06:18 PM
