Part Number for 2024 Grille
Hello
First post so I hope this is in the correct section.
Would anybody know, or know where I might find, the part number for the new grille that comes on the S Line models post-2024 (image below)?
I've tried to find it on a number of parts diagram websites but haven't been successful.
Thanks very much.
Thanks very much.
Hello
Thanks very much.
Thanks very much.
King$layer (04-29-2024)
DadAudi (04-28-2024)
Hello The radiator grille as in the photo has the number 4K0853651T3FZ. To change the dummy, you will need new elements such as those in photo number 18, 30 and probably something else. I'm going to replace the dummy with this one
Thanks for the reply. My current grille doesn’t have those gaps or dummy pieces (in truth I’m not even sure what they are - is it something to do with lane assist if that’s an option on the car?). Does seem like swapping to this type of grille might be a bit more involved than anticipated.
DadAudi (04-29-2024)
To me in order to do this and be unique you will need to add / takeaway things to make it yours. If you have a great body shop, then yes the possibility is more real then not. WhenI wanted a catback for mine, I can not begin to tell you the slippery slope I went down. But in the end I ended with a great conversation rear ended and 100% greatful I had done it. Then sadly two truck accidents later I ended being handicapped and NO more cars for this guy.
If you are a gambler....
Wait long enough the grills you are looking for will end up on AliExpress. The Chinese revere the A6-8's (especially their home built L versions) as the bomb. There are a lot of customization mods you can get for really reasonable prices. But...it is AliExpress so if you do use them, buy from a seller that claims easy returns, as you don't know for sure what you will get, some will be as close to OEM and some won't.
Got an S6 rear diffuser that is spot on. The Chinese have made a bolt on quad exhaust kit (that takes some cutting of the original exhaust tip) that comes with it. Will be installing it soon.
Take DadAudi's advice. You could be tripping down a path of tweaking just one sensor etc etc that will void your warranty and you are paying out a ton of money to do an electronics/MMI overhaul etc etc. .
Cheers!
PS: That Grill does look nice.
Cheers!
The following 2 users liked this post by Weaktor:
DadAudi (04-29-2024),
AizazBlack//S4
08-26-2001 08:43 AM
