View Full Version : Audi A5 / S5 / RS 5
Pages :
2]
10
- RO: Tire 265 35 R19?
- Boost on S5
- 2018 S5 Presitge coupe-No Center mounted tach option in virtual cockpit?
- UK: 2015 RS5 Coupe Knocking from the rear :(
- Upgrading the audi speakera
- New member w simple question
- Knocking noise under deceleration
- Dash not lighting up, no power steering and rough idle.
- Rough cold start
- Intermittent Battery Charging issue
- For Sale: b9 s4/s5 034 Dynamic+ Lowering Springs and Pure750 Turbo
- New S5 Owner, Couple of Questions
- A5 Quattro Rear Diff rumble
- BA: Audi A5 3.0 Quattro gearbox issue?!
- AU: Driver leg space, Audi A5 2011 Quatro 3.0TDI
- Help! Major Issue with my B8 2.0 Audi A5
- Selling old Audi tires - brick & mortar store?
- A5 Cabriolet 2013 bulb nightmare
- 2023 Audi A5 with 48v MHEV system?
- deactivating start/stop
- Glovebox Removal - HELP!
- New to Audi… PLEASE HELP
- Airbag crash sensors daily code
- 60K Miles "Major Maintenance" on S5 Sportback
- A5 Cabrio Powertrain changes between 2019-2020
- Did my 2013 A5 cabriolet come with a wind deflector?
- Wireless Carplay
- 2013 S5 has 140K miles - extended warranty available?
- For Sale: Complete Weathertech set for '09 S5
- AUDI A5 2018 interior ambient lights gone
- Audi s5 brake kit on a5 sportbsck
- AUDİ A5 OİL CATCH CAN PROBLEM
- 2011 S5 3.0t knock front of engine
- A5 factory ride height
- For Sale: Parts B9 S4/S5/SQ5 - 034 s34 & x34 Full Carbon Intake and more FREE
- 2012 A5 Convertible Sensor & Latch
- Quad tips on aftermarket dual exhaust
- Looking at buying a low mile 2014 A5 2.0T- Anything I should be looking for?
- Rear trunk lights driving me crazy
- XM Favorites Disappear
- *EXTREME* Electric Malfunction - looking for wisdom & fix ideas
- CEL is still on after I flashed IE stage-2 tuning
- 2014 S5 wheel bearing bolt stripped
- Street legal 2015 S5 tuning
- Audi A5 2009 (3.0L V6)
- For Sale: Pure 750 *Brand New in Box* Get it B4 Christmas with FREE SHIPPING
- B9 S5 Stage 2 upgrading to Stage 3/3+ - New Pure 750 & 034 x34 Carbon Intake For Sale
- First post b8.5
- Anyone want to talk me in or out of a B8.5 RS5?
- B130C11 Double subwoofer speaker 1 Short circuit to ground static.
- Car leak help?!
- B9 Cabrio broken rear seat release cable
- Aftermarket parts
- MMI updates & key programing
- Ambient light coding A5 B9.5
- 2013 Audi A5 Convertible with blown cyclinder #3
- B9 2018 Audi S5 Sportback
- S5 Cabriolet Dead battery & trunk won't open
- SE: Are the a5 coupe and a5 sedan spoilers interchangeable?
- First post for my Stage 2 B9 S5 SB
- Audi a5, Front side light on
- Ball joint pinch bolt?
- Gearbox Malfunction!?
- Oil level
- Puddle Lights Audi A5 Coupe 2009
- Audi S5 Front Parking Aid Malfunction?
- Headrest question
- Built in dash cam for 2018 A5 Sportback?
- BLACK FRIDAY SALE,, SuperSprint Italy
- 2018 A5 Coupe S Line - Apparent subtle Ticking/Knocking from engine bay when cruisi…
- DE: Problem S-tronic dl501 0b5
- Buying Advice 2013-2015 RS5
- Does a rs5 diffuser fit on a a5
- A5 Sportback2013 buzzer for parking?
- On Board Handbook
- PL: Shock absorbers from 1be to 1ba?
- 2024 S5 tips or tricks?
- 2009 Audi S5 blowing fuse #5 in engine fuse box
- oil capacity
- I am new to Audi - looking to purchase a used S5 advice please
- Clutch Went out need help
- Looking for A5 convertible northern NJ area
- A5 Cuope 2012 Catalyst system and O2 sensor issue
- Transmission service questions/confusion
- A5 doesn’t want to start when engine is warm.
- 08 S5 MMI blank
- Noise / Vibration improved and brake pedal noise fixed
- sportback liftgate window trim
- ambient light
- Module Coding Advice - Great Independant Required?
- Brake fluid extraction from Reservoir???
- Creaking steering...SOLVED
- 2017 A5 Cabriolet Inside Edge Tire Wear
- Constant noise/spinning sound coming from Virtual Cockpit while driving
- 2021 Audi A5 Yellow Grease
- S5 4.2 Thermostat?
- Carbon Fiber exterior removal
- Injen intake sounds quiet.
- Aircon issue A5 sportback B9 2020
- RS5 - Turbo Upgrade Suggestions
- Part number for driver side rear wheel well flap/spoiler
- S5 - Difference between 2023 and 2024?
- 2018 A5 Quattro Premium Plus Coupe Trans Failure
- Should I buy an extended warranty for my 2021 Audi S5 with 81k miles?
- Engagin Reverse gear SHOCKS car !!! help
- Sounds like a rock in between the brake pads, but dealership claims it’s the exhaust.
- KR: Get a part number?
- UK: lectronic Dampening Control Module - Location & Advice?
- A5 Coupe Battery and Alternator
- Please help. Centre diff location for oil change?
- Is there a bra available for the S5 SB?
- HVAC control unit replacement (CP)
- Wing mirror dip whilst reversing VCDS mod
- Vanity mirror switch not working
- Do not exceed 6000 rpm only on cold start up
- Coolant on A5 2018?
- Simple fix if radio volume control button works erratically
- Low Engine Oil Pressure
- Best website for OEM parts?
- Audi a5 2018 2.0 ( 190HP) suction from the engine oil cap?
- 3.2 Component ID
- A5 8T3 - *Park Brake Malfunction J540* - Help?
- Can you Disable ABS
- 2019 S5 SB Black Optic Fender Inlay Question
- 2023 Audi s5 no front towing thread
- Audi S5 Coupe 19k Miles For Sale
- Where is the coolant sensor (2018 S5)?
- Aluminium insert scratched.
- Audi S-tronic 0B5 DL501 problems at just 110K(183K kilometers) miles
- 2019 S5 sports back
- 2019 Audi S5 Front pads and Rotors for sale OEM
- PT: Audi A5 2015 Reverse signal?
- NO: Audi RS5 brakes shaking
- 2014 Audi S5 P0302+P0507 CEL. 120k miles
- Audi A5 MMI stopped updating and went to red /green
- Car was hit by truck in parking lot
- Really need help Audi gearbox gone doesnt move at all but goes into gear…
- 2014 Audi S5 Convertible Top Switch Replacement
- A5 Climate Control Issue
- Wondering about what exhaust modifications I should get.
- Oil for differential A5 SB 2021
- Audi A5 Clutch/flywheel torque limit
- rear bumper gap
- Losing battery power overnight - Help?
- Audi Exclusive build question
- What is this sensor hanging from my passenger side wheelwell?
- Feedback regarding vehicle maintenance?
- 2019 S5 Sportback. Amplifier upgrade. Intermittent front woofers
- MMI Error: No data connection could be established
- Transmission
- 2008 a5 no power steering
- Location of DC-DC Convertor
- Is Vaico transmission oil ok for DSG service???
- Sports Mode Audi S5 2012 B8 V8 4.2L
- G61 Knock sensor & CMP G301 Errors in 4.2 CFS engine
- Seatbelt Positioner Not Working
- Android Auto stopped working
- Cvt gearbox
- Service Audi, change brake fluid
- Any threads on here for pics of b8.5s?
- Exhaust flaps stuck open?
- UK: Mr?
- Ambient Lighting Question on 2023A5
- P057100 - Cruise/Brake Switch (A) Circ Malfunction - Active/Static
- set navigation tab on virtual cockpit as default
- steering wheel buttons are no longer illuminated in the dark
- Driving on a donut ? 2020 S5
- Which Build Is My Audi A5
- can't find crank position sensor (coupe b3 2.3e)
- P149c00 egr coolant pump open circuit
- B9.5 Level Sensor
- Help with Broken Floor Mat Fastener Replacement
- A5 2022 MMI engineers menu access
- How can I just have the DRL come on when I unlock instead of the DRLs AND Low Beams
- HELP: Radio - no sound / Emergency Call function malfunction error
- 2023 A5 45 Sportback, no trunk sticker. Can someone post a pic of theirs?
- Trunk wont open, doors won't unlock by touch, keyless push to start don't work.
- Just bought an rs5 2011, i need help identifying this thing.
- Thinking about buying used S5 4.2L 2008-2020 to modify, looking for advice.
- Low dust brake pads 2023 A5?
- Audi S5 B9 - DRIVE SYSTEM FAULT
- A few problems?
- 2023 S5 Cabrio black out trim kit?
- Help with the removing the part
- Audi rs5
- UK: Vibration and Drone to Motorway Speeds
- A5 main beam head light problem
- B9.5 Sportback Sunroof Glass Replacement
- Oil Pressure Light
- 2011 4.2L S5 crank no start
- 2012 Audi a5 won’t start
- RS5 price negotiations possible?
- Rear camera installation faults
- Looking for a B8 Audi S5 Rear Diffuser
- 2008 (b8) S5 coupe coolant fan relay
- 2024 RS5
- APR Plus vs Normal Stage 1 Tune / General Reliability
- CA: Desperate plea for help - Crashed My S5 - Insurance not covering repairs
- A5 coupe spoiler on A5 sportback spoiler
- Rock Chips on hood, no paint code in trunk.
- ES: Soft top roof repair?
- 2011 S5 Convertible.....4 months of repair insanity
- IE: Clutch slippage? A5 3L Quattro 218PS B9 2017 Automatic
- Coolant issue S5 B9
- S5 B9 Strange Cold Start Noises??
- Tail light wiring
- 2013 Audi RS5 transmission issue no gears at all
- 2023 Audi A5 mods
- Steering: malfunction!
- Audi A5 2011 B8 Wheel Hub and Bearing Replacement
- Subwoofer not working - Audi A5 S-Line TDI sportback
- A5 ab8 and B8.5 diffusers
- Engine Control warning
- 2008 Audi A5 Not Starting?
- AWE Exhaust Options
- Armrest
- MMI controller/wheel mouse select click not working
- Audi A5 Window seal - water getting into door frame
- Removing rear view mirror cover?
- Roof Rack Sunroof?
- VCDS Coding Help: Accent Light in A5 B9?
- Luft-Technik Intercooler 2016 A5
- Can't remove climate controls from dash on MY2023
- Anti Theft Wheel Bolt Kit Question
- Does the 2021 A5 SB hold value?
- AUDI A5 8T gap between window and seal
- Audi a5 2007 3.0 tdi manual gear stick worry
- 2014 A5 cabriolet convertible
- Audi S5 rear clunking noise
- 2020 S5 - Trailer Hitch ?
- I’m thinking about buying an 2008 s5
- Grill Part Disappeared
- American message board members.....
- VEICO or MEYLE Wheel Bearing? Are those OEM?
- Headlight problem
- Headlight LED signature
- Aftermarket light up grill logo
- Water Leak in Spare Tire Well - Audi S5 Sportback B9
- 22 A5 Sportback amp wire diagram
- MMI Upgrade - is it worth it?
- Using older 30pin iPod with 2019 A5
- 2023 A5, gas pump keeps clicking off before the gas tank is filled
- MMI factory navi vs Audi connect Navi?
- Sticking MMI buttons
- A5 Quattro 2014 Fuel issue
- Removing Silicone From Convertible Rear Window
- Looking at leasing 2023 A5 45 Sportback, what about all these issues I read about?
- Audi A5 2102 reverse gear issue
- Rear Diffuser
- 2008 S5 4.2 V8 B8 Service / Maint. @ Audi Dealership Car Won't Start
