PDA
View Full Version : Audi A5 / S5 / RS 5
Pages : 1 2 [3] 4 5 6 7 8 9 10
  1. Stage 1 tune, Driveshaft failure
  2. 2014 Audi A5 Not Recognizing New Part Causing Lights to Come On
  3. Power steering
  4. Convertible Roof Repair in San Diego
  5. Audi A5 S5 RS5 Service And Repair Manual
  6. Power steering
  7. Connecting rod bearing failure 2018 S5 sportback
  8. Audi A5 Sportback 2015 camera?
  9. B9 RS5 Rotors and Pad Options
  10. Issue with SOS emergency system
  11. B9 RS5 Bull-X Res Delete Exhaust Leak Issue (Clamps)
  12. ZA: 2010 A5 piston replacement?
  13. ECU Swap
  14. Troubleshoot: what the heck is this noise?
  15. Question about Adblue level
  16. Problem with rear console-seat heater
  17. Parking sensors keep failing
  18. Transmission Froze?
  19. Greetings from SuperSprint Italy
  20. Audi S5 4,2l V8 2010 0-62 in 6,5 sec… Why?!
  21. Can I reset ADAS with OBD Eleven?
  22. 2010 Audi A5 Crank No Start
  23. Staggered wheel set up query
  24. UK: Staggered wheel set up query
  25. Child lock fault contact workshop
  26. AC acting strange
  27. 2010 A5 3.2 P0018/P0019 Camshaft/Crankshaft Position
  28. AU: 2010 audi a5 convertible
  29. S5 B9 exhaust valve mod - moving the location of the valves - any potential issues?
  30. Oil level warning disabled by dealer
  31. Audi a5 2.0 tfsi 211cv thermostat
  32. Audi RS5 Options
  33. Audi A5 loud squeak please help
  34. UK: Engine Light On / Oil Change
  35. Motion App
  36. Flap motor v159
  37. RS5 2024
  38. Oil Pressure Regulator valve location
  39. UK: Audi A5 - Gearbox Error
  40. Adding Navigation 2023 S5
  41. Soft top problem
  42. What is the average lifespan of suspension system?
  43. Squeaking suspension, alignment performed recently.
  44. ODBEleven Nightmares
  45. Part of undercarriage came apart while driving at highway speeds - what part is this?
  46. Cup Holders Placement
  47. CarPlay Question
  48. Crazy Carplay Issue
  49. A5 Matrix LED Headlight
  50. MMI module failed...
  51. Body parts
  52. Audi Black Box
  53. Dyno Heartbreak on a Custom Tune
  54. Audi A5 sportback starting issues
  55. B8 A5
  56. New 2023 Audi A5 45 slight shake when idle or in park
  57. What is this part (behind the battery in the boot / trunk
  58. A5 B9 Convertible - Adding a space saver wheel
  59. 2012 A5 won’t start or crank
  60. HELP!my 2023 A5 sportback's MMI touch screen is not responding
  61. UK: Audi a5 sportback 2l diesel 2011 - Turbo issue
  62. 2017 sportback mods
  63. A5 Should I change the chain?
  64. Cracks on the Dashboard
  65. Sirius XFM pre-sets
  66. New 2023 A5 Sportback 45 TFSI - JB4 or RaceChip
  67. Broken Headlight Tab
  68. 2023 S5 Oil Change (non-dealer)?
  69. UK: Audi s5 2010 convertible electrical issues
  70. Can anybody help with 13 plate S5 clutch/gear box issues
  71. UK: 2009 Audi A5 3.0 diesel MMI
  72. New to the community, just have a few questions to ask
  73. Audi A5 Range?
  74. LT: Airbox Flap (?)
  75. Help! Low Coolant Shut Engine Off Warning Again!
  76. A5 Sportback now or wait for the next-gen model?
  77. Help with Front Diff Rebuild/Parts (UK spec)
  78. 2018 Audi S5 Popping/Clicking Noise From Steering/Dashboard
  79. Two questions
  80. SY: I'm looking for audi a5 tv analog tuner 4E0 910 146 H lak 00100
  81. 2019 S5 DIY Brake job
  82. 2011 Audi s5 Push start conversion ?
  83. UK: Audi a5 3.0 tdi manual gear stick worry
  84. 2023 A5 Sportback Issues After One Week
  85. New '23 S5 Died All of Sudden
  86. 2019 S5 Cabriolet subwoofer wiring diagram search
  87. 2018 A5 climate control module
  88. VW ID7
  89. Concert Radio
  90. Audi Software Update - 2018 Audi A5 Sportback Technik (Prestige)
  91. UK: New key coding - Audi can't connect to CCM??
  92. Do these tires fit my car or not?!
  93. Soft top warning not locking
  94. Unknown transmission mount splash guard identification?
  95. Trade Camaro for S5 Cabrio?
  96. What is this part called?
  97. 2020 A5 satellite maps not working after recent fix
  98. 2019 RS5 Brake Job - $7800+!!!!
  99. 2018 S5 3.0T Limp Mode
  100. Wheel upgrade questions and concerns
  101. A5 2.0 252HP Stage 1 concerns
  102. 18 a5 sportback problem
  103. A5 Sportback 2021 MMI issue
  104. UK: Gearbox issues? 2016 facelift 6 speed manual
  105. Extended Warranty 2019 Audi S5 Sportback
  106. Subwoofer instal Audi A5 Sportsback
  107. DE: audi a5 convertible top problems
  108. 3.0 TDI power loss
  109. Help! I have a 2017 Audi a5 Coupe (B9) and the front passenger seat won't return from
  110. 2015 A5 won’t start
  111. Buying a used a5 and is this crack ok?
  112. A5 quattro mysterious brakes getting hot
  113. Transmission Mount
  114. S5 3.0T - What do I need to know?
  115. NEED HELP. I THINK THE DEALERSHIP IS TRYING TO SCREW ME OVER
  116. Audi A5 2.0 TDI 2019 - Air rush/acceleration noise?
  117. Headlight up leveling issues Audi 2014
  118. Driver Seat tilt cable
  119. R8 Brake rotors fit?
  120. 13 S5?
  121. ZA: 2010 A5 2.0 tfsi egr valve?
  122. Multiple Short Circuit to ground fault after first ever drive home in torrential rain
  123. Issues with B8 RS5, Dead Battery, trunk release
  124. Driveshaft/Propeller Shaft
  125. Audi A5 EPC light on , no crank , all Electronics inside work
  126. 2014 A5 has a few issues
  127. 2011 A5 2.0 Fuel Consumption
  128. Audi a5 AC strange issue
  129. Meaty tire size for Audi S5 SB B9.5?
  130. S5 Front Seat Tilt Handle Problem
  131. Chrome door handle replacement
  132. RO: Thumping wheel noise and wheel play
  133. Audi RS 5 Ceramic Coating Maintenance Wash
  134. Dashboard unit 17 Software update
  135. 19 s5 sport back transmission fluid
  136. S5 Sportback Dashcam
  137. CV issue
  138. Can i put a super charger on it?
  139. Are B9.5 RS5 reliable? Anybody with 100k miles +?
  140. VCDS Fault code 4765
  141. New to Audi, looking for some modding advice
  142. RS5 2021 headlight washer do not retract.
  143. Tail light disassemble
  144. Audi A5 B8 Sportback - Noise from front and loud engine
  145. Audi 8T3 Adaptive Cruise Control sensor questions.
  146. AM/PM won’t change?
  147. Connections on sending unit help
  148. 2018 S5 window won’t go all the way down. About one inch or so from fully going down
  149. UK: A5 3.0tdi What figures are people getting from stage 2 tune?
  150. RS5 illuminated rings
  151. Help with engine noise
  152. "Gearbox Malfunction: you can continue driving (limited functionality)"
  153. Help identifying a part that broke off car
  154. driver door window regulator broke
  155. RS5 no window tint scratches
  156. LT: Distronic
  157. A5 2.0T TFSI Intake?
  158. Audi S5 2023 MMI Screen Trim removal
  159. Check engine light 2015 A5 after adding oil, needing oil or oil change
  160. Usb Port replacement
  161. Need Replacement Key Fob
  162. % OFFER - Carbon Ceramic Brake Discs
  163. Left storage compartment audiconnect box?
  164. RS5 Exhaust Problem?
  165. LT: Non dinamic headlights
  166. Weird humming noise
  167. Remote key FOB replacement?
  168. New owner
  169. 2011 S5 4.2 6spd AT Shift problem
  170. Nav Updates
  171. A5 Cabriolet Rear Light Fuse
  172. Rattling Noise When Clutch is Depressed
  173. VVT Solenoid placement
  174. 2023 A5: oil temp display?
  175. No response phone?
  176. PPI inspection revealed below minimum coolant level on 2018 S5
  177. Back up camera not working on 2011 A5
  178. B8 S5 Audio Issues
  179. MA: A5 soft top (what is this part ?)
  180. EPC light crank no start list of part replacements
  181. SE: Timing chain upgrade?
  182. So long gang - It's been great
  183. Loud dog whistle type noise coming from brake
  184. G62 Sensor location? Anyone know
  185. Replacement battery for 2017 A5 Cabriolet
  186. Would you buy this S5 based on the VCDS report?
  187. Navigation and bluetooth issues
  188. Audi A5 2.0TDI 2010 making very loud creaking noise from steering column
  189. 2008 S5 Fuel Tank Overpressure?
  190. UK: Exhaust valve rattle on my b9 s5 after catless downpipe
  191. AUDI A5 ELECTRONIC STEERING RACK NEEDED
  192. UK: A5 Cabri 2011 roof issues
  193. Audi A5 Sat Nav Problems
  194. Concert radio turns off
  195. B9 S5 Squeaking sound from engine bay (cold start)
  196. Audi A5 3.2 over-torqued oil filter cap?
  197. 2022 S5 Sportback w B&O - is a sub Worth it?
  198. B8,5 A4 headliner same as B8,5 A5?
  199. Audi S5 3.0 TFSI 2013 chain rattle
  200. Funky Electric Seats
  201. S5 clicking noice
  202. 3.0tdi Problems with the fuel transfer pump.
  203. RO: Engine almost stalling, automatic transmission
  204. License plates
  205. Six months to fix RS5
  206. 2013 Sportsback - Wing mirror cables question
  207. S5 Japan import MMI bootloader
  208. Swirl marks and chip in the hood on a new S5 normal?
  209. Sound form the pedals
  210. Armaspeed Customer Service - 100%
  211. 2013 S5 3.0 coolant fans wont activate
  212. V8 RS5 gone very quiet and unresponsive
  213. EG: Extremely in need to decide, Daytona Grey clear PPF VS Matte PPF
  214. CarPlay & Speech Dialogue Not installed
  215. 2012 4.2l S5 Rear Sports Diff Went...
  216. Heaps of Faults - Potential ECM Problem - Any Experience to Lend?
  217. 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
  218. 2019 Audi S5 Sportback Drop In Air Filter?
  219. Q5 3.0T vs Q5 tdi 3.0
  220. AE: AUDI RS5 B9 SPORTBACK NON FUNCTIONAL
  221. What did you do to your Audi today?
  222. CZ: Lub Bolt Size B8 RS5
  223. Drivers door red OFF button and Light above Temp control
  224. Ghost or mystery battery drain
  225. Looking for a 2010 S5 passenger side headlamp unit
  226. 2019 RS5 SB - ABT piggyback engine control install
  227. 2014 Oil/coolant issues
  228. New 2023 S5 Jack in trunk?
  229. 2023 RS5 hardwire radar detector mirror tap vs fuse tap
  230. ZA: 2010 A5 Sportback Oil level
  231. Audi S5 B8.5 Exhaust
  232. Anyone successfully install nefmoto
  233. Aftermarket parts and Warranty question
  234. Looking for an oil pump upgrade for 08 S5 4.2
  235. 2014 A5 Coupe Headunit/Module?
  236. Cabrio Issues
  237. HELP: MMI update restart Loop
  238. ReDisc - Carbon Ceramic brake disc refurbishment & repair
  239. UK: A5 Sportback S Line 35 TFSI 150 FUEL ECONOMY (UK MPG)
  240. What is this noise when driving over reflectors? (2015 S5 Coupe)
  241. Ride opinion B9 S5
  242. 2018 RS5 Fender Part Number ?
  243. New S5
  244. PK: Audi a5 racechip?
  245. 2018 S5 - 100K miles - How often do you get an oil change?
  246. Audi A5 1.8 TFSI [Sudden Misfire on all Cylinders]
  247. S5 b9 sportback b&o aftermarket sub and amp install help.
  248. 19in wheels?
  249. Red Brake Light and Orange Pad Lights are on
  250. Air Pressure Sensor wiring?
