View Full Version : Audi A5 / S5 / RS 5
Pages :
1]
10
- View feature Customization Question
- Trunk keeps popping open
- Want to buy a set 10 spoke OEM wheels
- MMI 3G+ is sleeping. Black screen. No power to fuse.
- UK: Emergency help needed
- Where to Stay For Best Driving Roads near Chattanooga/ATL/Knoxville?
- Cabrio + Dashcam
- How to find non-dealer Audi service
- Anyone interested in 2024 Rs5 competition Lease Takeover
- Coding
- 0CK gearbox MTF oil genuine or not
- no cold air ! Lots of hot air !
- Need help identify wires of hood latch or impact sensor
- Fibre optic ring
- Audi Exlusive Colors
- Idea to reduce exhaust noise - Magnaflow
- Sport Diff fault after intalling aftermarket headunit
- CZ: Ulter exhaust for the 155kW 2.0TFSI?
- 2018 A5 Cabriolet Prestige Trim Hands-Free trunk
- Lost communication, malfunction cannot be reached
- Wrong power steering fluid how to flush it out ?
- Considering a trade
- 2017 A5 2.0 S-line cabriolet - O2 bank 1 sensor
- Sporadic difficulty starting
- Oil dipstick
- LT: Identify this freon tube holder
- Carplay Issues!
- Audi Rotors on A5
- popping noise from rear, even when car is off.
- First Audi Experiance?
- Post Pics Latest Gen RS5
- Help please 97 Audi cabriolet stalled P1106 & P0306?
- Blue smoke on 3.0tdi
- BG: 2010 A5 cab soft top release problems
- Integrated Dashcam
- Wiring diagram for instrument cluster 1997 audi Cabriolet?
- Abnormal transmission issue
- Delivery Day!!!!
- Crank but no start and clicking noise in center console when car is on
- B9 A5 headlight wiring issue, bad ground or missing part
- Fault code reader not showing codes?
- Audi a5 diesel injector failure
- 2017 A5 Cab Subwoofer Wire Tap Location
- 2018 A5 Cabriolet Soft Top small frays - repair thoughts?!
- A5 intake manifold
- please help me find what this leak is!!
- Do not exceed engine speed 2500rpm
- New Member 2024 S5
- 2018 Audi RS5 engine rattle under 2k
- Audi s5 2012 facelift?
- Audi A5 2023 leaking in water
- DTC P1743 CVT clutch sensor high
- Is my 2020 Audi A5 Sportback 40tfsi or 45tfsi?
- MMI issues
- New 2023 A5 Cab kicking off P04F0 code
- New '24 RS5 Sportback PPF, Windshield Protection, All-Season Tire Rec's
- RS5 Sportback detachable towbar recommendations
- Hi my car problem with 26321 - Cam Adjustment Actuator B: Cylinder 5 P11B4 00[167} -
- Anyone experienced these codes?
- Anyone recognize this sensor?
- Folding mirror doesn't operate correctly with the door closed
- Which rear bumper fits my 2018 Audi A5(B9) Coupe Premium Plus?
- Hello; Audi A5 service 80k query
- UK: Where do I stand with Audi?
- Intake Manifold bolts keep breaking…
- 2024 Audi S5 sportsback
- 2012 S5 B8 Stuck in park. Help!!
- ? % off MSRP 2024 S5 Cab Prestige or Premium +
- 6hp 28 METAL Sealing Sleeves Transmission Service
- A5 and MMI - Hotspot ended
- Audi A5 idle running problem
- 1997 audi cabriolet front axle bolt torque specs?
- 2008 audi a5 steering wheel replacement options
- Oil Change Reset Question
- Winshield vizor
- Rear brakes getting hot..
- Need some help please / broken parts
- Seeking advice on used S5 Cabriolet
- Ambient light
- New Ride
- Audi s5 b8 rear diff fault
- RS5 sell it or keep repairing it question ??
- 2009 audi S5 limp mode
- Knocking under light acceleration.
- Condensation issues
- Timing / Inlet Camshaft Help!!!
- A5 Virtual Cockpit screen alignment
- 2024 A5 40 vs 45TFSI ride quality
- 2018 A5 Updated IE Stage 1 Tune Clutch Slip
- 2010 S5 major electrical failure.
- Clutch pedal is hard and transmission grinds in each gear
- 034 Motorsports P34 Intake Fitment Issues
- New car. Stock plugs and coils, aftermarket tune. Misfire.
- 2012 Audi A5 won’t accelerate
- Cabriolet headliner unglued
- S5 gearbox malfunction warning
- No sound
- his and hers build (2024 RS5 Competition)
- Tire pressure
- How to get into trunk with no battery?
- Engine issues?
- Soft top not closing at very end of cycle
- A5 B8 Tuning/Mod Advice
- SPORTBACK?
- PLEASE HELP!! Fuel Filler- Water Leaking into trunk boot
- VCDS - Battery "Not OK"
- I think i will hate my color choice...
- Does Anyone in this Thread have a 08-09 A5 3.2?
- 09 Audi A5 3.2L Fuel Pocket Water Leak in to Trunk Boot!!
- MMI Issue
- 2021 S5 Prestige Cabrio
- Soft top unavailable
- Strange Noise from the Steering Wheel
- Are you able to adjust the boot lid?
- MMI DISPLAY SCREEN
- Steering Wheel Upgrade and MMI Update
- Audi a5 b8.5 keyless start engine help
- RS5 Sportback Canada vs USA
- Resonator Delete Weld VS Clamp Kit
- Audi A5 Sportback 2020 Dash Cam Hardwiring Help
- How difficult is it to replace the silver trim on the bottom of my steering wheel?
- Sport Differential System Fault
- audi a5 b8.5 drive select install
- XM not displaying full information
- B8.5 Engine misfire, rps censor, thick smoke.
- Audi S5 Speedline Wheels for sale $1000 OBO.
- P2184 with no AC
- Turbo
- Drive position sensor P179E00 and P179E00 error after ATF/Diff service
- Fun Project
- Audi EPB issue
- Does Audi tend to under rate the output of their current motors?
- 2019 Audi A5 Sportback Central Driveshaft Bearing Whining Noise
- passenger's window not working. plz help me!! T_T
- Headlight and seat belt issues
- Reading Oil Level
- Intercooler Pipe Ruptured
- To Sell Or Not To Sell (2018 B9 A5)
- B & O subwoofer not working
- 2013 Audi A5 2.0t AC not working
- 2018 s5 engine blown
- Which color a5 Sportback to get?
- 2018 RS5 shock oil leak
- 2011 Audi s5 EPC light
- A5 headlight diagram
- Seat Belt Tension Fault Driver Side ( resistance too high) - B10061B
- Audi s5 2013 engine noise
- Changing steering wheel but don’t know the Base Audi S5 2012
- CH: Bang noise when accelerating [Quattro 2.0 TDI] 2017 A5
- USBC Under Armrest Not Working
- Power Steering water damage
- 2022 A5 B9.5 Auto Start/Stop
- Audi S5 2018 B9: Trunk Won't Open and Driver Door Interior Lighting Malfunction
- Loose lower grills on 2011 A5 Cabriolet
- outside rear view mirror problem
- Hood form a B9 to a B9.5
- Leaking Oil PLEASE HELP
- What Platform?
- 2010 A5 rings
- New Audi S5 owner.
- ECU and/or TCU tuning options for 24 MY S5/B9.5
- UK: Anyone have any experience with a Sytner select warranty?
- A5 cabrio Soft top Stowage Box Motor
- Steering Rack Failure - 2018 A5 Quattro
- Electrical issues
- Slow releasing clutch sometimes
- Electric Power Steering
- Soft top storage box motor
- 2009 A5 passeneger door continually trying to lock (darining battery)
- UK: Audi A5 Oil level and bonnet / hood sensor
- LT: How to open trunk from the inside ?
- Oil leak, again
- 2018 RS5 thinking about selling.
- A5 sportback suspension question
- B8 Audi S5 AC condenser bracket
- B9.5 s5 coding ambient lighting upgrade
- navigation upgrade.
- Fitting mini-spare in B9 or B9.5 convertible?
- APR ECU Search
- Audi RS5 ( 2012 - 2016 ) front RS Bumper
- ZF8HP Problem shiftdown
- AL: Audi A5 2.0 190ps quattro - cold engine noise
- B9 A5 Knocking sound fixed!!!
- 2013 Audi S5 Floor mats
- RS5 coupe whine noise at high rpm
- 2010 audi s5 v8
- System Voltage Low
- Urgent Help Needed: Audi A5 Coupe Electrical Failure
- installed Carplay to A5
- Rough idle on start up.
- Retrofit Side cameras into Mirorrs
- 2015 RS5 Coupe Gear oil replacement intervals ?
- A5 2007 VCDS - lights malfunction - Lights stay on and wipers dont work
- Wheels for S5?
- 21 A5 Sportback vibrates/Shudders while making a turn
- Issue login to mmi a5 sportback 2020
- How does S5 drive on NYC roads?
- Audi S5 Ground Clearance
- Car Locking & Unlocking While Washing
- A5 Carbon Spoiler
- What Would You Do?
- AUDI S5 SPORTBACK 2018 TICKING/RATTLE NOISE
- Crash bar
- Ordered RS 5 Sportback Comp Today!
- Snapped a lug bolt…
- Seeking a tune without warranty impact
- CH: How to know if headlights are matrix?
- Let's play identify the wire!
- Two pops when trunk is opening
- 2025 S5/RS5 - Any info?
- New 2024 S5 OEM Tire Question - All season vs Summers
- 2018 A5 Sportback 52k miles needs new engine
- A5 B9.5 Aftermarket Subwoofer Troubleshooting
- Mic sensitivity of voice memos app is very low
- 2011 A5 coupé front sensor
- 2019 RS5 79k Humming noise
- Can anyone name this part?
- Audi A5 HDD failing
- Key fob not identified. Car won't start
- 2019 Audi A5. Just got an oil change and the car is saying it’s overfilled.
- S5 new owner questions
- Audi Pre sense
- How to lighten an S5 Cab (not AC delete/back seat delete)
- Starting Issue - Audi S5 2024 (6,000km)
- UK: Spare set of Alloys TPMS or not ?
- First post. Looking for a B8 RS5
- AL: Question on the A5 2017
- activate RS5 Reversing camera B8
- A5 Cabrio - all years
- BiXenon headlight upgrade options on 2015 Coupe
- Weird shaking/chugging noise + low fuel economy
- Engine Display
- Engine Display
- Distribution kit
- Differential oil change
- Can I use this oil in a 2018 S5?
- Bad Fuel?
- 2019 A5 Sportback - Squealing Sound While Accelerating + White Exhaust Smoke at Idle
- A5 won't start when colder than -5
- S5 Top Arm, Rear Bush Replace - What Else?
- “Audi side assist: system fault”
- WTB b8.5 a5 exhaust parts
- Audi A5 B8 S Line 2.0 TFSI Cabriolet 2016 BLOWER
- Cold air dumping in passenger footwell
- Intro: New to me RS5
- K04 B8.5 A5 19” x 10” max tire size
- Help locating wiring harness for Side Assit
- Loss of compression what to do?
