View Full Version : Audi A5 / S5 / RS 5
Pages :
6]
10
- Engine without warning shuts off on hwy
- Audi A5 stereo Help
- S5 V8 Passenger Side Engine Mount Clearance Problem
- Emission control system warning and parking sensor malfunction
- GCC MAP SD card download for A5
- UK: Will this grill fit my B9?
- 2011 S5 Convertible heated Seats permanently on, Cooled Seats don’t work
- Cooling Fan and Generator - Fault codes
- 2022 Audi S5 - expected production/delivery dates?
- 2009 Audi A5 3.2 engine code?
- M O S T
- 2022 M3 xDrive or 2021 RS5 Sportback
- 2010 S5 4.2 V8 Rougle Idle Strange Problem
- Android Auto sound vs Bluetooth
- Jackpoint jack stands anyone?
- UK: A5 2009 2.0 tfsi massive high long term fuel trim
- UK: s5 vs rs5
- A5 Sportback trailer hitch?
- UK: Sat Nav question
- Need help identifying part 2020 audi a5 sportback prestige
- Annoying Text Message Beep
- RS5 B9 inlet pipes
- UK: A5 HELP
- JB4 and Unitronic?
- A5 sportback: swap rear bumper?
- Seat Height RS5 Coupe
- Purchased a '21 Audi S5 Sportback Today
- Audi A5 - Camshaft/Crankshaft Error
- 2018 A5 Convertible B9 Carbon Hood.
- Should I Scratch The Itch? I Want An S5 Sportback
- New Factory Orders on Hold?
- Potentially Fuel Pressure Failure?
- 2020 A5 Cabriolet rear view camera poor quality
- 2021 RS5 - How do I reset the trip counter?
- Audi A5 seat lock?
- 2019 AUDI S5 REPAIR MANUAL
- Can't remember Bluetooth pincode?
- head unit
- S5 V8 AT swap to Manual 6 ST
- New rs5 headers
- Twin turbo model/spec
- Constant faint metal rattle sound?
- 2018 S5 grille to 2020 conversion
- B9 A5 MMI UPDATE
- S5 - Used pricing & DSG reliability?
- Service Due Reset?
- 2018 s5 convertible
- Audi Care - Maintenance - Service etc
- Audi equivalent of Real OEM
- Faulty Bonnet/Hood Sensor
- Paddle Shifters NOT Working!!
- 2018 B9 S5 Sportback Intake?
- RS5 B9 stage1 remap
- Anyone here wanted a white S5/RS5 and bought gray and regretted it?
- Contact Photo on MMI Telephone System
- UK: Parcel shelf?
- UK: A5 tfsi 2010
- Spark Plug Change
- What is this part?
- 2013 - 2016 Audi RS5 Ceramic Left Front Caliper
- 2014 rs5 launching
- Change Audi Vehicle Displayed on Virtual Cockpit
- rear seat back not folding
- 1994 Audi Shifting Constantly
- Oil capacity?
- Help! Damage from bad VVT solenoid? 3.2 A5
- Missing Front Bumper Sensor
- Adaptive Cruise Control
- Coasting downhill in neutral bad for Quattro?
- 2018 S5 Cab prestige - Black Grill
- Should I be wary of getting a 2015 S5 with 140,000+ km?
- Passenger Door Module Issue
- 18” to 19” wheels on 2013 A5?
- Steering Wheel Crease Question
- Coupe black edition plus boot spoiler
- Mechanic, Philly?
- 2009 S5 - Key must be fully depressed to start
- New 2018 S5 Sportback Owner
- 2018 S5 SB Headlight Trim Loose
- Audi S5 B9.5 rattle when accelerating
- 2018 low miles S5 no CPO?
- 2019 B9 S5 Key Batter Holder Replacement Options
- Akrapovic exhaust for RS5 (B9)
- Hot Vee / any associated problems?
- Weird noise in reverse
- Order Timeframe - Exclusive
- 2013 A5 B8 Rear Lower Control Arm Bushings
- 2011 Audi 25 4.2l Throwing misfire codes
- Knock sensor
- AU: Audi A5 3.0 TDI 2012, Transmission Problem ?
- A perfectly non-car question
- 2022 A5 Custom Order Hiccups
- A5 B9 Coupe Interior Rattling
- Audi A5 B9 2018 high pitched whining coming from nearside front at cruising speeds
- Airbag Module Fault & Reprogram
- Changing Wheel Size for Winter
- Will they total my car?
- Any help
- How to reset Inspection due alert?
- 2013 Audi RS5 tank sender unit
- Oil sucker
- Rear diffusers are compatible between sportback & coupe?
- Carbonplug.com Complaints
- 2021 RS5 Nardo Grey
- [DMV] AWE Track edition exhaust S4/S5 B9
- 2022 S5
- UK: Tick?
- Rs5 b9 passenger side ticking sound??
- 2014 Side Assist
- Help with my 2010 Audi A5
- Question about Lowering a S5 an inch
- 2014 S5 Manual
- Passenger door not unlocking and mirror not folding
- 09 audi a5 3.2 no manual, no start
- Tell me how the he*@ to get the expansion tank cap off!
- 2021 Rs5 tune?
- First RS5
- Milltek Exhaust Valve Issue (Open and Close on start)
- 2021 Audi Q5 - Gateway Control Module Failure?
- transmission malfunction+tpms malfunction?
- Audi A5 2019 CPO
- 2008 S5 4.2 V8 AC compressor
- Power tailgate struts
- Paint repair question
- Audi s5 help
- Stick on mirror cap covers vs. replacements
- REVO intake fell off while driving and i think i blew my motor...
- Good price on OEM winter tire and wheel package?
- Anyone In Southeast/Mid Michigan With a 2018 RS5 I Could Test Drive?
- 2009 S5 lots of issues need advice
- Rs Grill
- New A5 Owner
- Race Chip for A5 recommendation?
- Audi A5 F5 2017 disable start stop system?
- Pre Sense Tried To Kill Me!!!
- Audi B8 S5 Whining noise when accelerating
- 2021 A5 DL-382 transmission upgrade
- Problem with tailgate opening from key
- B9.5 RS 5 Winter Tires?
- 2019 A5 Wrench still on dash after obdeleven?
- Unable to remove 2015 S5 Convertible passenger side headlight lens
- A5 does not have standard boot top cover
- RS5 or RS6 Avant?
- MTM cover under the hood
- Engine tick
- Audi A5 Premium 40 Sportback 2021
- Gas Choice?
- Key Fob Relock Timeout 2020-A5
- 2021 Audi A5 dyno mode
- 2018 S5 Prestige, Experience
- Thumping Noise When Oil Cap Is Taken Off
- 2008 Audi A5 2.0tfsi P0016
- 2011 A5 engine swap?
- Broken myaudi and audi finance
- Adaptive light fault.
- A5 2013 cabriolet “soft top cannot be used”
- Wheel Help
- 2021 A5 centre console difference between European and US model?
- 2.0 tfsi inlet manifold question
- 2013 Audi S5 Rebuild
- S5 b8.5 odd squeak from engine please help
- AUDI RS5 Exhaust Setup
- 3.0L TFSI SC Oil
- You Tell Me the Oil Level??
- UK Newbie from Birmingham, England
- Help buying a 2019 RS5?
- Audi A5 2.0 TFSI whistle sound
- New Nardo S5
- Buying a 2018 A5, is the extended warranty worthwhile?
- Key Fob
- RS5 Coupe rear reflector delete - Nardo Grey
- 2012 A5 2.0 TDI alternator bearing
- 2010 Audi A5 Engine Swap
- First Oil Change - How long past a year is OK?
- NO: Trouble after 2.0L diesel engine rebuild
- Not Audi connect
- New member: Thoughts about this S8-Cab I'm considering?
- Looking to buy s5 rotor wheels
- 2017 Audi S5 Startup and Revs. Check it out guys.
- Help!!!! top left corner of the screen and shows “ScreenID=xxxx” MMI 3G plus
- 2013 S5 crank position sensor location
- Exhaust Valve open coding or unplug hack
- Audi S5 2012 Sportsback
- Excited to Join the Audi Family! 2021 RS5 Sportback
- Audi S5 not starting.
- RS 5 Keyless Entry System Re-Sync Question
- 2021 A5 Sportback Premium
- Prices Rs5 cabrio
- New member
- Some Sort of Felt Mat Ripped Off froom Under Car?
- 2019 S5 265R30-20 to 275R30-20 Upgrade
- Factory orders 2021?
- Audi A5 Sportback 2018 modell, side skirts and doors not alligning
- 2008 rear abs wiring loom
- Strange Noise From FL Tire
- Slow Rev drop between gear changes
- Audi A5 alternator voltage output range
- 2014 Audi A5 hesitation
- Audi A5 Cabriolet OEM Dual Exhaust
- 2021 S5 grill
- 2021 S5 Difference in Premium vs Prestige
- Anti-Theft Precautions???
- White dot periodically on tachometer?
- 2021 Audi B9 S5 SB cosmetic upgrade questions
- Hi there, i'm jamila
- Results Rs5 2013 Dyno run
- 2011 S5 B8 4.2 Intake Manifold Actuator Issue
- TPMS & Parking Brake failure
- Protuninglab grill advice
- Question about A5 SB 2011
- Damaged Hose Air Intake on S5 3.0 : is this one fatal?
- 19 S5 SB grille
- My first Audi: 2018 S5 Convertible
- Rattling sound when coming to a stop?
- Audi A5 2010 coupe preface lift - B&O speaker blown, need replacements?
- MOMO RF wheels for B8 S5 V8
- AUDI S5 2009 FOG LIGHTS RELAY HEEELP PLEASE
- Rs5 Spacers
- 2021 A5/S5 ordering guide?
- Flashing how-to with JHM's new flashing server
- GEMMI vs Upgrade to AA/CP unit
- RS5 amplifier
- Shopping for A5, comparing with BMW 430i
- Ordering Time Frame
- How to service carbon ceramic RS5 brakes
- 275/30/20
- UK: FWD 2.0 TFSI vs 4WD 2.0 TFSI
- UK: Gearbox Malfunction
- Help! 2008 2.7 wont start
- 2008 Audi A5 TPMS control module location
- HELP! HELP! Audi A5 20" Wheel Offset for aggressive look
- Priceless
- Black Line Mark on Rear Rotors
- A5 Cabriolet - Golf Clubs
- UK: MMI amp/stereo unit water damage
- Purchasing Cabrio RS5 or S5
- Can I change key user name?
- Wireless charging taking priority over usb-c connection?
- Audi A5 2009 - Exterior Handle Not Working
- UK: Waterpump v36 error
- 2021 S5 SB Interior Lighting Package?
- Little green light.
- Mud flaps
- Grinding sound
- BH: Thinking of modifying my 2021 A5 coupe
- Audi s5 down on power
- BOV vs Dv
- Frequent windshield cracks - 2016 S5 Sportback
- ACC alignment cost: $1200!?
