View Full Version : Audi A5 / S5 / RS 5
Pages :
9]
10
- A5/S5 door sensors: OEM vs. After Market...
- best shops for B9 S5-SB in Los Angeles?
- annoying buzzing in the front dash S5 b9
- Emergency SOS malfunction
- 2011 Audi A5 won't recognize iphone 7 with blue tooth any more
- what discount did you get on a new RS 5 coupe
- Ny Audi App: Login Failed
- Tire pressure for winter tire? S5 sportback
- Changing or delting presets
- 2013 S5 Beeps or Chirps while off and parked
- Audi A5 2.0 TFSI Quattro - Fuel Economy
- Why bother with Audi Connect Prime?
- Hello Everyone!
- Winter Tire/Wheel Set 2014 A5
- 2010 S5 Cabrio Module Swap out...
- Power Steering Pump Pulley Size
- Front arches rubbing at high speed
- APR ECU software with GIAC DSG Tune
- Need help with tyres! Which to buy i'm confused A5 coupe 2010
- S5 winter wheel offset
- Valvetronic exhaust?
- Does my S5 2.0L engine need a catch can?
- At a loss...
- Heating issue on my a5
- Brake wear sensor question
- S-Tronic DSG oil color?!?
- 2010 B8 S5 - Check Engine Question
- Grille and bumper replacement
- Compact voice guidance
- Audi a5 b8, rs6 steering wheel?
- EA888 or CAEB cylinder head for 2011 A5?
- Certificate of Conformity for Audi (Importing CAN to USA)
- Exhaust S5 B9
- Tuning my 2012 Audi A5 B8
- Question about Buying my First Audi
- Data transfer password request
- 2013 Audi A5 S Line DSG, WON'T START, PLS HELP
- Upper control arm bushings
- Issues with CarPlay - 2019 A5 is driving me crazy!
- RS5 b9 f5-are there tasteful CarbonFibre bodykits?
- EMD Auto RS style grille
- audi s5
- S5 Convertible top headliner fell
- keys, synchronization?
- Audi A5 MMI CP Help
- Where did you Purchase your OBDEleven
- Stiff clutch & loose gear shift
- Which model is this? RS5 or RS7
- Noise from supercharger
- Instrument Cluster Replacement
- Dynamic Drive
- Annoying noise in rear compartment
- S5 b9 sportback
- S5 front lip scraped.. any suggestions?
- 2017 A5 2.0T
- Snow cables for 2019 S5 265/30R20 tires
- RPM Surge
- A5 Clutch Issues
- Help engine size. Buying Audi a5 Coupe 2014
- Turbocharger replacement
- 2016 A5 bluetooth
- Help Errors: P0068, P0507, P2279
- battery ?
- Speedometer display km instead of Miles
- Squeaking noise from steering a5 coupe
- 2011 A5 build
- 2011 A5 no radio station reception
- *** 2020 Audi A5 - Press release today! ***
- 19 S5SB spare tire tool kit?
- Timer for RS5
- Help!
- RS5 hardwire radar
- S5 b9 virtual cockpit
- Seat belt feeder rattle
- Cranking Problem
- UK: Audi S5 2012 3.0v6 DSG Gearbox Mechatronics Issue - advice appreciated
- 2010 Audi A5 secondary air injection problem
- Paint Protection?
- 2019 Audi s5 window issue
- 2018 Certified S5 10 digit Key Code missing
- Question about AUDI Diagnostics
- New Project Car
- part name ?
- 3.2 or 2.0T?
- Cleaning bug stains from paint
- S5 soft top detached right side window from cover
- 2012 A5 MMI
- Cranking problem
- My New Baby
- HRE wheel question on S5 sportback
- Audi MMI Address 07: Control Head Cannot be reached
- Back rattle in A5 Sportback
- S5 Sportback Red Caliper question
- Convert mmi 3g to carplay and color
- a5- b8 engine codes- p0113
- Code p0068
- Rear Axle Seal Leak
- My car will not unlock with fab
- RS5 2010 - What engine oil to use
- 1st check engine light
- Access to can bus / 2012 A5
- 3.0 3.2 maintenance
- Engine Bracket Help!
- A5 Avant 3.0t? Last in USA?
- 13 S5 worth 24k?
- rs5 sb
- Dealer Repair Quote...Need Advice
- Premium Plus vs Prestige (Traffic Jam Assist)
- Considering RS5 SB...Newbie Questions
- Wide body kit
- 2011 a5 start then stalling problem
- S5 A5 Convertible Hard Top
- 2008 A5 Engine Trouble Codes
- S5 b9 driver foot rest is hot
- ECM HELP
- A5 B8 S Line rear muffler hanger replacement
- Black residue on passenger side exhaust tip
- Satellite radio/ MMI
- Racechip/other tunes
- Vibration in right passenger door found.
- Creaking from the rear...
- homelink issue with S5?
- Leaking in the boot footwells
- 2012 (B8) Audi A5 Coupe, Ice silver or blacked out
- SiriusXM renewal
- Rattle on startup
- Transmission code p179c00
- HOW CAN I GET V I M ON MY 2019 RS5
- Ambient Lights Not Working
- RV Car Care
- UK: squeaking while driving please help
- Passenger Side Window Exploded - '18 A5 SB
- AC out
- Service due displad on dash
- Audi RS5 8T 62 plate
- Tires (All season)
- to rip CD to Audi jukebox or use memory card
- MMI Question
- Groaning creaking Suspension
- 2019 S5 gasoline?
- MMI not working
- Help please, vídeo input on MMI 3G basic
- Audi A5 oil fix help please
- Audi S5 extended wtty ?s
- A5 Wobbling ACC Sensor | "Sensor blocked" warning / removal right fog lamp cover ?
- New S5 sportback dealer price
- Can I put these tires on my audi
- Media upgrade
- 2010 A5 maintenance. HELP.
- 2011 Audi RS5 problem starting
- MPG on A5 Sportback versus A4? Real life
- 2011 A5 Cabrio pulls to right
- Is the 16’ S5 and reliable and safe vehicle for a 18 year old?
- MMI no longer charging device
- 2018 Audi A5 Rear Lamp Wiring Diagrams needed
- Change MMI button mapping?
- Audi A5 Very Laggy
- What oil??
- Check engine light on while engine is not on.
- SDMP4 to SDMP3
- 2016 S5
- Quattro
- Car Seat fitment?
- Diagnostic trouble code p0016 on my audi A5 convertible 2009 year
- Picked up a 2010 A5, help with 2013+ facelift
- Trunk Lid Inoperable
- A5 2014 Audi TV - clarification needed if possible
- (ADVICE) Looking to purchase 2011 A5 Coupe - Reliability Issues / Known Problems?
- (HELP) WHICH TRANSMISSION? 6 or 8 Speed Tiptronic?
- 2011 A5 Coupe - sunroof shade
- Check coolant warning
- Drivers side armrest
- Coolant gremlin.
- Engine cover
- mmi is on but no sound
- New RS5 - Red - Carbon Fiber Package - Black Badges
- Audi A5 acoustics improvement options
- 2010 S5 4.2l - fuel rail pressure too high and low voltage readings
- Lowered my 2019 S5 Coupe
- Switch from A4 to S5
- Flat Spot A5
- 2009 S5 4.2
- Seat belt
- Audi A5 Android headunit help
- HUB AND BEARING REPLACEMENT
- Engine light PO341 error
- Sportback Sunroof + Roof Rack / OBD11 Help Needed
- Smartphone Interface (Android Auto) not available
- Purchased 2019 s5 problems after visiting dealership
- Newbie exhaust question
- errors
- RS5 subtle clicking
- audi a5 front license plate brackets needed
- OEM Continental Tire performance
- Deals on 2019/2020 RS5 Sportback
- Pre Sense City
- Rotors
- A5 Blower / HVAC issues
- Honeycomb grill for S5 2013
- Looking to buy my first car
- Swapping a damaged Virtual Cockpit
- BLASPHEMY, i know. AST on RS5 advice
- Adding OEM options?
- 2019 audi s5 sound system issue
- Parts Help Canada
- Was the first A5/S5 best looking?
- A5 engine blown at 52k; dealer and AoA not helping
- A5 - Cant stream music from phone
- OBDEleven traffic sign recognition
- Nardo S5 SB on Blaque Diamond Wheels
- Apple Music Playlist via Bluetooth Streaming - Can't select listed songs
- Android head unit
- S5 sportback wheel spacer
- PPF choices- premium shield?
- What? No Phone Box in that new RS5?
- Expected miles on new factory ordered RS5 sportback
- AUDI a5 FL/PRE FL quarter panel replacement
- Fresh air blower: short to plus
- 2011 S5
- Secondary Air Injection Pump
- Can useing a battery to small in my a5 make it run wrong?
- Options for fixing / replacing front bumper 2013 S5
- Understanding start/stop conditions
- RS5 Dynamic/Individual
- Help AC not working and obd code p261a
- A5 - Wipers won’t work (Wiper Defective error)
- S5 engine types
- 2012 Audi A5 Underboost Code, Seems normal
- Capristo sport exhaust
- Coolant leak
- A5 front lower control arm & rearward lower control arm ball joint
- Fogged side mirrors
- S5 Homelink
- Replacing B&O sub in my A5 SB
- oil going into coolant reservoir - audi s5
- 2010 S5 PRESTIGE MANUAL BLACK FOR SALE
- BH: A5 1.8 B8 Shifting delay and hesitation at 1st gear
- A5 to S5 to RS5 in 18 months
- RS5 sportback front license plate removal
- A5 original window sticker
- 2013 Audi A5 Crank No Start
- A5 LED headlight is turning yellow!
- Changing Steering Wheel
- ‘15 vs ‘16 A5 Possible Purchase
- Tire & Wheel Protection
- Android Auto connection
- A5 coupe very high RPM's going downhill
- Android Auto cards
- ECP or not?
- Warranty advice
