PDA
View Full Version : Audi A5 / S5 / RS5 (B9)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. 2019 RS5 SB: Passenger Side Seat Belt
  2. Google Maps adding Traffic Lights
  3. standard tire size for 2021 s5 coupe
  4. Oil blowing out my cap?
  5. Anyone with vcds data logging experience on 2018+ RS5?
  6. Disable Auto/Stop w/VCDS
  7. Air filter: Wrap or no wrap?
  8. Wrecked my RS5 Sportback what to get next?
  9. Wrecked my RS5 Sportback what to get next?
  10. 2009 S5 power steering pump
  11. 2009 S5 power steering pump
  12. After market sound system
  13. Aftermarket sub amp tuning
  14. Track Edition AWE exhaust
  15. 2019 RS5 SB- Fuel Gauge Issue
  16. Something Rattling in Front Right Door
  17. Audi Connect
  18. Beware of changing RS style grill for your S5 in Great Toronto Area
  19. Sound clip request: Milltek non-res catback with a high-flow cat or test pipe
  20. Winter Wheels: What to Look For/Avoid?
  21. Replacing the door speakers
  22. New RS5 or keep manual S5?
  23. Trunk Space (Sportback)
  24. Buying a car with aftermarket wheels?
  25. TPMS question for tire/wheel not on the car
  26. SD Card slot in a MY20 S5?
  27. Found this on the drivers door, any ideas?
  28. First mods for the RS5...
  29. Burning smell, what is this part with some splash around it?
  30. 2013 RS5 questions
  31. sport adaptive damping
  32. TSB 2052251/4 Bang & Olufsen: Audio distorted from all input sources
  33. Just installed AWE Exhaust - Some Questions and Comments
  34. Bringing up this again
  35. So back from the dragstrip with some baseline passes...
  36. Please help with replacing alum. trim molding panel
  37. Hit 20k miles, woohoo!
  38. 2019 rs5 catback exhausts
  39. Modeled and 3D printed my own shift extensions
  40. Downside of auto parking brake on shut down OBD11
  41. 2019 ... Video in motion possible yet? (with either ODB11 or Vagcom)?
  42. New S5 owner. Got some questions.
  43. Benefit from Only Adding a Sub
  44. Just picked up 2019 Sonoma Green RS5 Sportback
  45. Brake Change
  46. 2021 RS5
  47. interior colors
  48. Anyone else's tint causes glare off rear defroster?
  49. 2019 RS5 SB Faulty Thermostat- long wait for parts
  50. Brakes suddenly engaged in reverse
  51. RS5 - Headlight turning off when turning steering wheel.
  52. Clear Paddle Extensions!
  53. KW V3 suspension, any reviews? Feedbacks?
  54. New (to me) toy... 2018 RS5 Coupe - Misano Red. Pics inside.
  55. Rear panel ambient light issue A5 coupe
  56. Tie Rod damage
  57. auto start stop on rs5sb
  58. MercRacing Complete Cooling System Solution for B9 RS5 😎
  59. Audi A5 Sportback front plate mount
  60. S5 8-Speed Auto and Sport Diff Service Intervals
  61. seatbelt arm
  62. Should Oil Change if Mileage Not Met?
  63. Custom Car Stereo
  64. New Grill - Sensors out of alignment
  65. Door windows not retracting/going down completely into door
  66. When will 2021 A5’s be arriving?
  67. For the wheel experts...
  68. LT: Damper size?
  69. Ticking sound from the front (S5)
  70. Another Audi Care Fine Print Thread
  71. MercRacing Air-to-Water Intercooler for B9 RS5! 😎
  72. Solved: Jack Storage in B9 S5 Sportback
  73. Picked a new toy up today... 2019 Audi RS5 Coupe
  74. Question for those with CETE AVC
  75. 2018 A5 vs 2015 S5
  76. If you dislike manually breaking 100 lb*ft wheel bolts see this:
  77. Aluminum Tommy Bar (wheel hanger)
  78. my new rs5sb!
  79. 2019 A5 Sportback Keyless entry
  80. ACNA
  81. Water vs. Oil Temperature
  82. S5 Cab Luxury Pkg Headrest Issue
  83. Comments of Pricing- new/used/certified RS5 Sportback
  84. Armaspeed Audi RS5 / S5 B9 carbon fiber cold air intake
  85. Adaptive Cruise Control w/o Automatic Braking?
  86. 2018 S5 - Any way to get WiFi without Audi Connect?
  87. Front Splitter Pics & Options
  88. A5 harsh ride
  89. Flex Fuel Sensor
  90. RS5 rear headrest removal?
  91. Auf Wiedersehen (or sayonara?)
  92. Changed out my headrests!
  93. OBDeleven fault code (U140600)
  94. New '19 RS5 coupe
  95. 2018 A5 SB sunroof ticking (video)
  96. Oil Level Gauge in VC upon startup!
  97. OBD Eleven error codes
  98. The DRLs are bright!
  99. Audi Connect traffic/nav vs Android Auto
  100. RS5 style grille install Toronto
  101. Annoying noise - S5 cab
  102. 2018 S5 traffic information in Canada
  103. Anyone with a resonator and muffler delete on RS5 with or without sports exhaust?
  104. 2019 RS5 Sportback Resonator Delete - Before & After
  105. Upgraded From S4 to S5 Coupe!
  106. Coolant Smell B9 S5
  107. TSB
  108. Spacers on 034 Dynamic Springs
  109. Brakes Creaking
  110. Seat Rattle (Passenger Side)
  111. Which way to go?
  112. 2019 S5 Sportback Standard Audio Upgrade
  113. Green Audi RS5 With Matte Bronze Wheels Flaunts Special Spec On Camera
  114. Dashcam powered via OBD Port
  115. myAudi App Reporting that the Windows are Open
  116. Thoughts on minor mod?
  117. Dealer dented hood
  118. Why is my car so audible when washing it?
  119. 2018 Audi S5 Brake Squeal!
  120. Subwoofer install - Audi A5 B9 Coupe - Audi Sound System
  121. Amping up the B9 RS5 Sportback B&O Subwoofer
  122. Door Handle Key-less Entry Sensor Reset?
  123. Random Higher Idle and does not shift to 8th gear in Lower Speeds
  124. Lowering and increase wheel size
  125. Aftermarket brake pads/rotors suggestions?
  126. What is your 2018 S5 paint code for Florett Silver Metallic?
  127. Location Pairing for Garage Door Opener
  128. Throttle House - New Audi RS5 Sportback vs 2013 Audi RS5
  129. RS5 Engine
  130. Have you installed an aftermarket subwoofer? Check your input wiring again...
  131. [CarWow]: Audi RS4 vs Audi RS7
  132. DP and exhaust options Rs5 b9 - in search of solutions
  133. Subwoofer and Amplifier Plug and Play cables
  134. Black Badges
  135. Tint 2018 S5 Sportback?
  136. A5 S Line bumpers on regular A5?
  137. S5 to RS5
  138. Broken pieces of acrylics inside grille?
  139. B9 S5 ECS Oil Dipstick Level
  140. ABT - ADDITIONAL WATER RADIATOR KIT
  141. Fatal RS5 collision
  142. 2021 Audi e-tron S = S5 in Performance
  143. Engine Sound - Clicking
  144. S5 Sportaback Seats - Question
  145. Gumout All in one
  146. Length and Weight Carry Limits on Roof Rack
  147. Kia's A5 SB Knockoff
  148. Engine oil type (Noob Question)
  149. 10k oil changes too much?
  150. Ecs cold air intake
  151. S5 seats are nice, headrest not so much
  152. Introducing OEM A5, S5, RS5 LED Taillight Packages...
  153. My new 2019 Nardo Gray RS5 Sportback!
  154. s5 b9 grille
  155. AC affects shifting
  156. Need RS5 brake pads that create less dust
  157. Sunday Tech/Tool Tip
  158. Color Matched Wheel Weights?
  159. 2019 S5 Sportback Rubber Trim
  160. Confusing Coolant Reservoir
  161. How hot is your oil?
  162. Post your dragy/trap times!
  163. Killer Chiller for RS5?
  164. 2021 S5 Sportback Order Placed
  165. Have to logon to AudiConnect every time I get in the car
  166. Window Tint
  167. JD Power initial quality 2020
  168. New MMI
  169. Impressive Mileage
  170. Idea re: Rear headrests
  171. Update! wireless Apple CarPlay NOT! Coming for 2020 models A4/A5
  172. Will 275/30x20 fit my new S5
  173. AWE Touring Exhaust Install
  174. Manual shifting
  175. Apple & Car Key
  176. I need a 19" wheel for my A5
  177. Upgraded my B8.5 Cab to B9 (Observations)
  178. RS5 Coupe - Trunk is like an oven????
  179. Intermittent But Annoying Cabriolet Soft Convertible Top Problem
  180. New here- Turbo Blue S5 SB on order!
  181. OBDEleven (Auto-Lock)
  182. 2018 S5 favors 1 of 4 exhaust pipes
  183. Quattro Theme on Blip Shift today
  184. Volkswagen to pay $267 million for Audi buyout
  185. Pulsing brake lights on emergency braking?
  186. Ball in a can
  187. Questions about spacers
  188. Drive system malfunction Error at the drag strip
  189. JB4 B9 S5 Install (full walkthrough)
  190. To all modders - Inexperienced member looking for advice
  191. AWE RS5 Exhaust
  192. Anyone know what is supposed to be mounted here?
  193. Anyone with Milltek Resonated Exhaust
  194. Stock tires in Winter Conditions?
  195. Soundkator - Exactly how does it work?
  196. RS5 APR Stage 1 Tune
  197. What a superb feature...
  198. Weird chirping while driving/moving only
  199. Carista (OBD2)
  200. Ideas to secure the Basser subwoofer box in the Sportback
  201. Soundaktor Fuse (S5)
  202. Sunglass Holder - NOT visor based?
  203. Audi RS5 Air filter pre-filter
  204. Red Lunge Near Redline?
  205. 2019 S5 Cabriolet - Turn on Auto High Beams (HBA) on P+ model
  206. Audi Extended Coverage
  207. What are your favorite voice commands?
  208. Autobahn: Fuel Economy at High Speed?
  209. The G22 BMW 4 Series Grille is Still Ugly.
  210. Covid -19 sanitize car and other info
  211. Real MPG Numbers?
  212. Any Tango Red Metallic owners find touch-up paint?
  213. my new wallpaper...
  214. Curious George and the engine bay
  215. Blow-off valve?
  216. Homelink - Garage Opener Programming?
  217. OEM windshield sunshade?
  218. ECS dipstick owners, can you read the oil level?
  219. Questions on ABT Suspension
  220. Electrical help, please!
  221. Tips for Spark Plug Removal/Change on the 3.0T V6 in the 2018+ Audi B9 S4 / S5
  222. Retrofit: 2020 Metal RS Paddles
  223. Potential A4/S4/A5/S5 Competitor?
  224. New Toy
  225. Window roll-up?
  226. [Video]: CarWow tests RS4 vs RS Q8 vs RS Q3
  227. Nardo Grey RS5 - Black OEM Wheels
  228. A5 S5 RS5 Sportback Soft Close Retrofit
  229. Audi cracks down OEM parts website?
  230. PSA- interior trim is different from SB and coupe
  231. Which Audi Blue Is This?
  232. GR: Advice on ride quality? (Prospective buyer)
  233. Will PPF stick to a car that has been ceramic coated?
  234. wheels for Winter?
  235. Window Sticker (VIN Decoder)
  236. Question regarding the steering wheel?
  237. Is anyone running ABT tune on S5
  238. Planning an S5.... 2019 or 2020?
  239. OBD11 tweaks
  240. Finally became Audi owner with new RS5 SB
  241. Quick Question: Kicker Key Install
  242. Map update
  243. Terrible new rattle in 2019 A5 SB
  244. VR Tuned ECU Tuning Box Kit?
  245. AUDI S5 B9 After jerking lost power
  246. Steering wheel Start/Stop/Select button kit?
  247. Any interest in corner sub for A5/S5/RS5 B9 coupe?
  248. Looking for new wheels: Lets see your wheels on the Coupe!
  249. Bang and olufsen settings?
  250. High Idle Consumption - Ideas?
