PDA
View Full Version : Audi A5 / S5 / RS5 (B9)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. 2014 RS5 B8.5 PCV Caps Popping out, Vacuum lines blew off intake manifold
  2. A5 sportback - 3.0 TDI - DCPE - OIL PRESSURE
  3. A4 Crash Bar Cover Fitment on A5 (2018 Pre-Facelift) ??
  4. A5 2021 - Oil Level Meter Not Showing Amount
  5. RS5 Winter tire - 245/40/19 vs 255/40/19
  6. A stunning yellow wrapped A5
  7. My B9 S5 VERY amateur Photos
  8. Volvo, VW and Nissan among companies that could face supply problems
  9. HPFP upgrade issue resolved!
  10. Looking for input on buying an A5 Sportback
  11. Inspection vs. "complimentary" inspection
  12. Got the letter...
  13. Any experience with Aliexpress interior lights?
  14. Floor mats for Cabrio?
  15. Oil temps down 10F+...Amsoil 0W-30
  16. 2018 A5: Low Windshield Washer fluid warning won’t go off
  17. Sunroof drainage location B9.5 sportsback
  18. 2019 S5 SB Random Parking Sensor Activation
  19. What the B10 Should Have Been
  20. 2021 RS5 - Unpleasant sound during cold start coming from the back.
  21. What is the point of an oil extractor?
  22. These are brand new and were never mounted or installed
  23. Tire & braking noise
  24. Engine rumble
  25. Leaking Water Pump?
  26. What are the quietest 20" tires for an A5/S5 Sportback?
  27. Do all 2024s have SFD2?
  28. Are these wheels interchangeable?
  29. Tires wears
  30. Slow/Intermittent Coolant Leak Months After New Coolant Components Installed
  31. 2022 S5 Premium - Coding Animated taillights
  32. 2018 A5 chip recommendations.
  33. Automakers Kill Touchscreens and Bringing Back Buttons
  34. Should this have been the new A5 Sportback?
  35. 2020 A5 front brake job
  36. Zimmerman Disc with Brembo Pads
  37. Finally getting my alcantara console body cover!
  38. Dealer damaged part# 8W0857115 but says it needs painting?
  39. 20" wheels on B9 S5?
  40. Replacement Windshield and Alignments?
  41. Did Audi create one of the most beautiful interiors in the B9?
  42. Intake Questions
  43. Tire change - need to go to dealership?
  44. What rotor size?! So confusing.
  45. Here’s how to bleed your brake fluid
  46. 2018 S5 Coupe getting a hear transplant
  47. Audi S5 OEM Exhaust for Audi A5?
  48. 0W-20, 0W-30, 5W-30 or 5W-40 oil in 2018 S5 B9 2DR EA839?
  49. Vibration (new aftermarket engine mounts)
  50. Bulb warning light intermittently comes on and loss of High Beam
  51. Genuine OEM or EBC slotted/drilled rotors + pads?
  52. Two underbody questions
  53. Notice Audi Extended Warranty
  54. Changing Tires to Improve Ride?
  55. Airbag Warning
  56. B9.5 S5 shuts off on cold start
  57. 1st gear intermittent short whine sound on a 2023 S5 sportback
  58. MMI and such
  59. Another 2-Door Hot Rod
  60. Redline Review '24 RS5 Throwback Review
  61. Gratuitous A5 Beauty Shot
  62. VPS Resonator Delete Kit Clamps
  63. RS5 Dyno Numbers
  64. Drivers seat easy access 21 S5 Coupe
  65. Leather/pleather interior of S5 cabrio - what do you use?
  66. Knoxville: Want to Learn to Flush My Brakes
  67. Fault terminal 15 open circuit b114813
  68. ZF8 maintenance
  69. Transmission code P284600, single instance
  70. Lane assist malfunction message
  71. 2.0 Tune suggestions
  72. Anyone else have foam-filled tires?
  73. So after just (72) days of ownership, I'm done...
  74. Fuel tank pressure sensor
  75. Audi OBD module
  76. Changing tire size?
  77. RS5 Eventuri Intake with Inlet pipe
  78. A Gremlin Future?
  79. No seatback locks?
  80. Direct TPMS module MIA?
  81. Front Diff B9 2019 2.0T & Haldex
  82. Extend Audi Care or go independent?
  83. How to Lower Cabriolet Wind Deflector
  84. Squeaky Seatbelt
  85. Remove headliner console and vanity lights
  86. Wheel Question for RS5
  87. Metal ball found after timing chain replacement – camshaft bridge question
  88. A B&O 38pin test harness
  89. Audi A5 left interior light
  90. SE: RS4 Stage 3 bad result in dyno
  91. Oil level between oil changes - need to top off?
  92. CarPlay connection issues? This might explain why
  93. Exhaust Tip Replacement
  94. 2018 Audi A5 Prestige Cabriolet Top Problem
  95. 2020 A5 MMI matte screen protector?
  96. Thornton Chip
  97. People are more "aggressive" around my A5
  98. 95 MPH Cruise Control Limit Increase
  99. 2018 RS5 rear shocks kaput! Need advice...
  100. Drive System Malfunction Errors
  101. Inlet pipe that works with the AWE intake ( RS5)
  102. My A5 stinks (literally) - normal AC deodorizing doesn't work
  103. New owners of redesigned S5
  104. Don't Want to Be An Ass/Dealer Question
  105. My New S5
  106. Intake filter for a '19 RS5
  107. New S5 Owner- Couple Questions
  108. Fuel ?
  109. Auditography's Video
  110. Cabriolet Windows Setting - Change Possible??
  111. Questions about installing tow hook
  112. Volkswagen Hit Hard by Trump’s Tariffs
  113. Noise from headliner area
  114. SOS Malfunction
  115. Oil change interval
  116. Looking to trade Front License plate holder for Filler Bracket 8W6807287BRP5
  117. Porsche S has also a EA839; same issue with Audi S cars?
  118. AC Issues
  119. Headlight adaptation fuxored
  120. New to B9 Forum- Question on if S line is lowered or the same as Sport?
  121. 360 Camera retrofit part number for mirror shell
  122. Ambient light on when unlocking your car - Audi B9
  123. side mirror damage. easy repair?
  124. Aftermarket wheels
  125. Will the B9.5 A5/S5 be a classic or will it become dated?
  126. 2023 A5 Sportback Prestige coming off lease - Buy?
  127. Audi A5 tachometer
  128. EVAP fuel pressure sensor
  129. Sportback. Cargo Area Mat
  130. How to use jack stands?
  131. Another S5
  132. B9.5 S5 Sportback Roof Clunking/Crunching
  133. New 2024 S5 Sportback Bumper lip.
  134. 24 S5 Cabrio. Ideas for cosmetic mods (interior and exterior)
  135. Towing a Caravan 2013 S5
  136. 500 miles in on RS5 comp and have brake/trans fluid smell...normal?
  137. MMI consistently forgets my "Favorites"
  138. New (to me) 2024 S5 Sportback
  139. Is there a mid body jacking point?
  140. WTB oem Audi sportback roof rack
  141. 0W-20 recommended oil and warranty
  142. Joined the S-Car Club, Sportback Edition (with some questions)
  143. rear res/silencer
  144. Wrong Navigation Directions
  145. China May Eat European Car Industry’s Lunch
  146. 2020 A5 MMI Randomly Rebooting During Drive
  147. Any online sources for B9 grille chrome strip inserts?
  148. S5 Rock Chips
  149. Audi Dealer won't provide details of service under prev owner
  150. Active lane assist problem
  151. Audi RS5 2020 Firmware Upgrade.
  152. Audi "Platinum Plus" Tire and Wheel Coverage NOT Quite Platinum
  153. Tuned Audi a5 oil choice
  154. SPEAK UP FOR AUDI- A Film By Audi's Desperate Community
  155. MMI - Wrong song showing on dash won't change as songs change
  156. RS5 at the Drag Strip
  157. What is this RFID sticker for?
  158. Matrix headlights?
  159. Transmission Error Problems
  160. Radiator Fan Spinning Too Fast When A/C Is On at Idle?
  161. Audi Smackdown of CarPlay Ultra
  162. Does mild hybrid drive begin in 2019?
  163. Cruise control curve slow down disable?
  164. My S5 (B9.5) 2021 Sportback Full Speaker / Audio Upgrade
  165. Engine Replacement – Audi Platinum Warranty - Facing $7K Out of Pocket
  166. 7 Years & Almost 39K Oil Analysis
  167. Steering noise... Control arm bushes?
  168. S5 B9 Cabriolet Antenna "Malfunction" - Help Needed
  169. What is this mess:
  170. TPMS - Dataset / parameter missing
  171. Detailing help!!!
  172. Canadian Tire - Castrol & Mobil 1 0W20 (508/509) on sale
  173. S5 b9.5 windows wont close
  174. New CarPlay Features In iOS 26 BETA
  175. HVAC Blower Speed Drops Intermittently
  176. Diffuser Audi A5 b9 Coupe non s line
  177. RS5 B9 Gateway Module Issue
  178. B9.5 20” Alloys
  179. Those with 275/30/20 on OEM wheels
  180. S5 Side Skirt Pictures Please
  181. B9.5 S5 Fog Light Retrofit
  182. OBDeleven and SFD2 ??
  183. APR tune for late model RS5 Coupe
  184. B9.5 S5 Cabriolet - Seatbelt Microphone Issue
  185. Buying a non-Audi, first time since 2006
  186. Anyone know similar wheels?
  187. RS5 B9 reliability
  188. Showed on ODBeleven U112300 - Databus error value received
  189. Looking for B9 A5 license plate bracket filler
  190. MMI Reboots/Freezes after Map Inititialization module
  191. Front arms change
  192. Reccomendations for an Aftermarket ambient lighting kit
  193. Rear Bumper Sensors
  194. UK: Buying 2018 Audi A5 diesel with egr dpf work done last year
  195. 2019 S5 Cooling Issue (AGAIN?)
  196. Tire Pressure Warning came on 3 times then went away
  197. Anyone done a resonator delete on a 2018 a5 sportback?
  198. Worn interior trim next to gear shifter.
  199. Squeaking in the steering wheel, Audi partner denies.
  200. Audi A5 Seats Vibration at Random Roads, Random Speeds
  201. Drone Mobile Issues
  202. AC repair/dealer woes
  203. A5 Sportback A/C Problem - Burning eyes!!!
  204. Bass sound flat after mii update A5 B9 B&O
  205. Car mods.
  206. Base Sound off after update
  207. Where is the Engine Coolant Level Sensor?
  208. Rear Valance Removal
  209. Formula 1
  210. Self Study Programme B9 RS5
  211. Upgrading stock speakers
  212. RS5 - Daily driving with res delete
  213. S5 Cabriolet - Powered Subwoofer
  214. SOS Emergency malfunction
  215. Brake Pedal Height
  216. Apple Announces CarPlay Ultra
  217. Heat Wrap?
  218. Hail cover for 2020 S5 Sportsback
  219. Oil & Filter Survey
  220. Audi’s new £88k entry-level e-tron GT
  221. Fault P0A1E00 Starter/Generator Control Module
  222. RS5 four wheel drive ECU fault....
  223. brake fluid flush
  224. 65634/65636 - Control Circuit for Tank Locking Flap
  225. Purchasing a 2018 A5 premium plus. Question on VC/Nav
  226. The saga of our replacement windscreen
  227. 2020 A5 sline Splash Guards ie mud flaps
  228. scanner to buy or use
  229. What's the current accurate scoop on SFD2 cars and diagnostics?
  230. Spark plugs at 41k
  231. A5 B9 2018 obdeleven oneclick apps not working
  232. B & O Tweeter upgrade for B 9.5 S5 Sportback
  233. Brake pads and rotor
  234. Traffic Sign Recognition on non-Prestige
  235. Looking for a similar wheel but larger.
  236. Sportback lights on the Coupe
  237. For Sale: TTE810+ (Upgraded Version) Brand New / Sealed In Box
  238. Rattling noise coming from overhead console
  239. Oil filter cartridge and Oil Plug torque specs?
  240. RS5 Oil Temperature
  241. New A5 SB owner seeking PPF advice
  242. Fuse amperage spec and layout
  243. 034 RS+ big brake package
  244. 2020 Audi A5 sportback front blinker light not working
  245. APR B9 S4/S5 Exhaust System! Great Gains. Deep Sound. High Quality / Free Flowing.
  246. Speed/ABS sensor issues
  247. brake caliper covers
  248. Time to replace the battery?
  249. Door seal besides window wont go in
  250. Subwoofer addition?
