- XM Notifications in 22 A5 versus 20 Q7
- S5 Body Kit Pics
- 22: AWD Missing Calibration / Malfunction
- For Audi A5 / S5 / RS5 2009-2018
- A5 versus S5 test drives
- The B9 + B9.5 Activations + Retrofits Information Post...
- RS4 B9 Stage3 Problem Please!
- looking for cat back exhaust
- Aftermarket DRL Boards
- Is It Safe to Drive S5 With 3 Summer tires and 1 Snow Tire?
- EA839 3.0L Turbo from a 2022 Audi S5: catastrophic overheat
- VW504 better for your car than VW508
- Bonnet (hood) regulation
- Fix or replace windscreen damage...
- Intro and exhaust question
- IE 91 octane stage 1 S5 tune experience
- Apple fixes CarPlay...
- front electronic struts recommendation
- Loud Trunk Noise when opening/closing
- Audi A5 2020 not shifting gear timely
- Odd behavior B&O sound in Cabrio
- 2018 S5 Cabriolet - Subwoofer Problem
- Manual Shifting
- Audi A5 Cabrio b9
- 2018 RS5 rear shocks question
- Troubleshoot: 2018 B9 S5 Misfire
- Motul 508 spec oil UOA
- 2018 A5 air filter box and leaves leaves leaves
- Carplay takes a really long time to play music?
- MMI user login error
- Parts in engine bay
- Audi "Themes"
- Winter Tire Fire Sale - $200
- Issues using misc phone functions
- Spotify MMI Display through Android Auto
- Audi holding cars in port due to tariffs
- B9 A5 fuel door won't open...😂
- Part number lookup please. CLUTCH pedal for a 2018 (B9) A5 manual trans.
- Sportback trunk not closing
- My impressions of my '25 A5 Sportback
- Thanks, Apple & CarPlay …
- Why are there so many used '24 A5s on the market?
- How to confirm water pump failure?
- Got the Road Hazard package and already used it
- Body Kits
- VCDS- oil level
- usb c not charging phone
- Extended Warranty
- Floor Pan Splash Shield Bolt
- Old VIN after MMI replacement
- Trump places 25% tariffs on auto imports
- 2019 Audi RS5 Knocking/Clunking Sound from Suspension - DRC issue
- Strange Error After Flap Motor Replacement
- New member in market for A5, questions.
- SüperDüper Turbo Inlet Upgrade Kit
- LV: AirBag changing
- Apple CarPlay not being recognized
- The problems continue RS5 B9 -19
- Front license plate
- B9.5-style headlights for B9
- Scandinavian DRL on Canadian cars
- Driver Side multicontour seat control module Leak detected
- Coolant Life and Hydrometer
- New to the board, just got a 2023 S5 Sportback!
- Ashanti Black label wheel help
- BMC filter captures a small forest...
- 20" Wheels and Tire/Wheel Warranty
- Do oem 19" B9 A4 wheels fit a B9 A5 Coupe?
- High Beam Assistant
- What is the best looking 19" OEM wheel for the A5 Sportback?
- Alternator replacement guide of sorts needed
- How to remove plastic cover in the trunk ?
- Accidentally removed the control/fill plug on the transmission
- Keyfob Battery
- Does the 2020 Audi S5 sportback progresiv have auto high beams?
- LV: USA to EU taillight conversion
- Replacing Roof Rubber Seal Attached to Chrome Trim?
- 0w-20 or 5w-30?
- First Post, 2 Questions
- Audi Pre-Sense False Operation
- White residue on the engine bay
- 2018 S5 Coupe stealth hitch
- Exhaust fumes only coming from one pipe/side
- Coolant Type - G12, G12+, G12++ etc
- Swishing sound from steering wheel
- 2019 S5 Cooling Issue
- EA839 vacuum disable active coolant pump and shutoff valve?
- A5 sport suspension ride comfort
- PLS HELP - coolant leak, misfire, bank 1 running lean
- How to Activate RS style animation - 2021 A5 B9.5 sportback Matrix LED
- 2018 A5 Sportback Matte PPF
- Wheel Locks + Wheel Spacers with OEM wheels
- For Sale: IE Performance Parts for Audi B9/B9.5 S4 & S5 3.0T
- Excessive water in door jams - 2024 4k miles
- Which oil spec for 2109 A5? - 502 or 504 ?
- Android auto stopped working
- All Seasons on a RS5
- Hesitation in MMI before Carplay music plays from my iPhone
- RS5 Side Skirts - Matte Finish Carbon Fiber
- Tire pressure monitoring on 2020 S5
- How to setup my audi app and update NAV on used audi s5
- Brakes (Pads) Don't Fit
- Which version of B9.5 is most owned here?
- Which model B9.5 is most owned here?
- Barometric Pressure Sensor "A" with check engine light issue
- A5 Gas Mileage?
- S-tronic DL382 software update q&a
- Missing airbag badge on B-pillar
- S5 HPFP gummed up
- Best Tire Pressure for S5
- S performance screen without touch screen
- An RS5 with the 5 Cylinder DAZA?
- 19" Cavo Wheels?
- Steering wheel lights not working
- A5 grocery bags solution
- A Design Comparison of the B9.5 vs. B10
- Which do I unplug for Soundaktor removal?
- In case you are undecided about color
- Coolant in Oil
- Please Drive to Warm Up Engine
- Matrix LED Pattern
- A couple of days with my new A5
- Why do my puddle lights stay awake?
- Insurance would total the car, but repairable – what to do?
- Unable to program Homelink in my A5
- DIY: Audi B9 2.0T - Oil Change From Under the Car
- A5 Reliability and Experiences
- B&O System in the A5
- Sunroof whistles when its cold out
- Headlight washer stuck
- Seats replacement
- 20" OEM wheels on A5 Sportback
- Zygrene Youtube B9.5 Rs5 SB Review
- RO: Oil type for 2.0 TFSI EA888 GEN3B?
- Factory Grocery Hook Solution for Sportback
- LV: S5 b9 / b9.5 boost leak test smoke
- SOS Emergency Call Error - Reset Step by step ?
- LV: Headliner removal sportback
- Car Battery
- Cracking noise from roof
- N428 valve disconnect = good oil pressure all the time?
- How to remove the panel under the steering ?
- Every single Audi to be named after its individual VIN number
- A5 Cabrio dash cam (FitCamX)
- Too Good To Be True?
- Brakes
- B9 RS4/RS5 Intake System From APR: Big power. Low lower price!
- Brake Service Light On
- New APR B9 S4/S5 Intake System: Big power. Full system. Low price.
- 80k ATF fluid change
- Front and rear sway bars question.
- Anyone seen an aluminum oil filter housing for Audi cars?
- Turn off traffic sign speed warning.
- B9.5 S5 Active/Direct TPMS
- Homelink visor for 2024 A5
- Persistent Oil Smell in the cabin / oil smell after revving or heavy driving
- Only 5 Coupes remaining in the USA
- Seat belt adjuster stuck - replacement procedure
- RS5 Tire Fitment (wheel spacers + tire size)
- Worthless Warranty
- Matrix LED activation in Minnesota?
- S-tronic DL382 Jerks
- Need help with rack on RS5/4 B9.5
- Very poor service from dealership. What should be my course of action?
- Window sometimes doesn't go down after replacing regulator
- The ole "should I take the wheel / tire insurance" question!
- New Rear Deck Spoiler
- Speedometer reading 4% high compared to GPS
- 2023 RS5 Check Coolent Levels and Shut off Engine
- 2020 A5 Cabrio Microphone Issue
- low pressure fuel pump system sensor lost connection
- Pleasant sounds compared...
- 2018 S5 Tire Pressure Display?
- Good physical dipstick for B9.5 A5
- RS5 2018 Fuel Filter
- Audi S5 B9.5 Jerky Gearbox
- S5 9.5 Pop and Bang sound upon startup
- A5 Sportback 2019 Lane Assist Button
- Why does it always happen when I'm out of town?
- Right door mirror forAudi ‘22 A5.
- Audi Pure Protection Extended Warranty - Deductible
- A little help needed re: water pump/thermostat issue
- B9 Rs4/5 capristo exhaust for 2022 s5?
- Zimmermann Brakes
- RS4 B9 Stage3 STILL BIG Problem
- Audi CNG Virtual Cockpit Retrofit
- FR: Audi A5 Sportback 40tdi how to remove the trapézoïdale belt
- S5 winter wheel fitment/spacer advice
- Dome light turning on fade in/out
- Sunglasses Storage
- 2021 S5 Reliability between 15k - 30k
- What happens to car value if you don't use it much?
- Remote Start Error
- Anyone using any external DSP on an Audi Sound System car?
- Anybody Try This Oil Filter Housing?
- What's that thing under the trunk floor?
- Is there a way to see current tire pressure?
- Urgent advice needed re: power Steering System Failure on Brand New A5
- Source for TSBs besides NHTSA?
- Summer tires in the winter?
- Accessing dashcam while phone is connected to car
- VCDS cable capabilities
- Orange Lock/Unlock Light possible all the time?
- Best email address for Audi America?
- Tapping in to DRL wire in Audi A5 2018 Sportback?
- 2020 b9.5 Audi s5 loud injectors?
- Databus Missing Message error in Comfort System?
- Aluminum bits in oil filter
- How do you remove the seat frame covers?
- UK/EU: Always on Blue laser light accents?
- How difficult is a chrome delete on the b9 A5 (2019 sportback)?
- New to the Audi family! Have some warranty questions
- Front roof glass
- A5 2020 B9.5 on 38,000 miles - error codes P0011 and P000A
- Help Request: New 2024 S5 (dash board rattling)
- 2018 S5 Two Door Navman Update Question
- MAP sensor part no.
- Android Auto wireless adapter Q
- M3 Touring vs RS4 Avant: The Ultimate Winter Test
- Brake Pads for A5 Sportsback
- Weak/No Heat: 2019 RS5 Sportback
- Chattanooga Mechanics?
- Recurring Error Codes that Audi doesn't fix
- 2018 S5 - oil "top up" needed after 50k miles - normal
- AWE Touring on B9 RS5 - Clicking at startup
- Transmission Control Module
- Fuel Pump mechanical error issue
- New Key Fob
- 21 RS5 - Broken Cargo Cover Fastening Clip
- 2019 RS5 SB and Coupe 20" OEM Wheels
- Opinions Wanted: “Single Phase Forged” Wheel
- Intermittent keyless entry issue
- 2024 Virtual Cockpit Settings
- repair manual
- Help with broken volume dial
- Outside temp display
- 2022 S5 Sportback Throttle Response
- Integrated Engineering Autoprotect and True Flex Impressions/Feedback
- 2018 S5 sportback heated seats stopped working
- Tire Pressure for the love of God???
- B9.5 RS5 vs 911 Carrera 4 (992.1)
- A5 B9 E85 Conversion
- 2011 s5 cabriolet. 3.0T
- What is Audi building for US?
- RS5 Jack Placement
- P225B - NOx Sensor Calibration Memory
- head restraint in audi a5 cabriolet
- Looking for some help with wheel spacers
- Front "fog" lights
