Does anyone remount wheels to extend their wear? I took out much of the outer edge at track, but the
Old Nov 1, 2000 | 04:34 AM
RR's Avatar
RR
Default Does anyone remount wheels to extend their wear? I took out much of the outer edge at track, but the
inside edge still looks OK. If I had the front tires swapped to be backwards on the rims and swapped side-to-side they would be rotating the right way.
Any reason to not do this?
RR
Old Nov 1, 2000 | 04:42 AM
Adam T's Avatar
New Member
Default I do with track tires.
I reverse the tire on the wheel, and it has lengthened the life of the Kumhos. I was thinking about doing this for the street tires too, but they would have to be pretty worn on one side.
Adam
Old Nov 1, 2000 | 05:12 AM
S4MULA's Avatar
Default At my next rotation I will have them remounted. My understanding is that the inside edges will wear
because the car is lowered.
Old Nov 1, 2000 | 06:42 AM
RR's Avatar
RR
Not at the track. It's all on the outside edge on my fronts. Need more neg camber!
Old Nov 1, 2000 | 07:17 AM
eharleq's Avatar
Junior Member
Absolutely correct! Bust this dumb myth, we need a LOT more camber.
Old Nov 1, 2000 | 09:15 AM
Corey S's Avatar
Member
Default It all depends on your alignment!!
You can run with the 1.5deg of neg camber in the front (when the car is lowered), but if you have a little toe in (like 1/16" or so), you can have very even wear on the tires.
At the track, it's a different story. If you have a good street alignment like I mentioned above, you will wear the outside edge of your tires on the track.
Old Nov 1, 2000 | 09:36 AM
gimbal (fight on)'s Avatar
Member
Default Some tires are designed with an "inside" and "outside" edge, check before remounting...
I moved my fronts to the rear to longer life. I also swapped the worse worn tire for my fresh spare. I have Michelin Pilot SX tires that have survived 5 track events.
JMSIV
Jul 21, 2005 05:54 AM
markbradford
Motorsport Discussion
Aug 19, 2003 08:19 AM
Silvr1.8T
Wheels & Tires Discussion
Oct 2, 2002 05:03 PM
AbnormallyAspirated
Jan 28, 2002 01:22 PM
