Just vagged my car, anyone with some advice would be great and well appreciated.....................
Old Jan 10, 2006 | 06:29 PM
Bliggity's Avatar
New Member
Default Just vagged my car, anyone with some advice would be great and well appreciated.....................
I went in for an oil change and these logs were found in my car:
16891-idle control system RPM:higher than expected
17521-oxygen (Lambda) sensor; B1 S1: Internal resistance too high
16684-Random/Multiple cylinder misfire detected
16687-cylinder 3:misfire detected
My car has been pinging latley, if I change the oxygen sensor do you think that it will fix the other problems??
THANKS!!!!!!
Old Jan 10, 2006 | 06:46 PM
Kevins42's Avatar
Possibly. It sounds like a bad O2 sensor.
Old Jan 10, 2006 | 06:59 PM
QCRAZY's Avatar
Should do a throttle adaptation too.
Old Jan 10, 2006 | 07:03 PM
rktskicar's Avatar
Default Are you using Shell V-power?
<ul><li><a href="https://forums.audiworld.com/pacificnw/msgs/62069.phtml">pinging on Shell V-power</a></li></ul>
Old Jan 10, 2006 | 07:24 PM
Bliggity's Avatar
New Member
I only use 93 from texaco or amaco, what is and does a throttle adaption do?
Old Jan 10, 2006 | 07:29 PM
rktskicar's Avatar
Default Bliggity. If your replying to my V-power post, put your reply below my V-power
post. If you take some logs with your VAG and post them , we can see if you are pinging or not.
Bruce
Old Jan 10, 2006 | 07:40 PM
VelocityS4's Avatar
Default my buddy had some o2 sensor problems as well as misfires. he replaced the o2's and its running fine
no more misfires.
Old Jan 10, 2006 | 07:59 PM
Bliggity's Avatar
New Member
local shop hooked up the Vag-Com, do I just need to ask him if I can drive for a few mins with Vag??
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 10, 2006 | 08:01 PM
rktskicar's Avatar
I think you should start with replacing the O2 sensor per VelcocityS4 suggestion above.
Blue2000S4
Mar 24, 2010 08:52 AM
ryry
Audi allroad
9
Jun 30, 2007 08:58 PM
postalChange
Jul 1, 2005 01:37 PM
justwentgerman212
Oct 17, 2004 12:19 PM
Howie Feltersnatch
Aug 25, 2003 11:31 PM
