Is periodically disconnecting the battery to restore power only required for chipped cars?
Old May 16, 2000 | 06:58 AM
harinder's Avatar
25 Year Member
Old May 16, 2000 | 07:11 AM
Jack Orr's Avatar
Junior Member
Default Re: Is periodically disconnecting the battery to restore power only required for chipped cars?
Do what? Me thinks you need to post more info.
Old May 16, 2000 | 07:32 AM
harinder's Avatar
25 Year Member
I'm talking about the loss of power symptom (not the tbb issue). I recall someone (maybe Ben) posting a procedure that required disconnecting the battery for 20 seconds and about 10 other steps which brought back power.
Old May 16, 2000 | 09:31 AM
Bollinger's Avatar
Elder Member
Default I think so
The reason chipped cars need to be disconnected once in a while is because the people who makes the chips aren't especially good at what they do.
So, they jack up some parameters to raise performance. Well, they didn't catch everything they need to change, because the engine management detects something is going wrong, and backs off. It then remembers to stay backed off so it doesn't operate out of parameters.
Disconnecting the battery makes it lose this memory and so it goes back to the original operation.
Eventually, somebody will make a chip which doesn't do this. Or else they will reduce the power output so it isn't causing these problems.
Old May 16, 2000 | 09:37 AM
Mike4.2CBW's Avatar
Junior Member
Does anyone know if this applies to the Tip chip too?
Old May 16, 2000 | 09:38 AM
harinder's Avatar
25 Year Member
That's what I thought. Thanks.
Old May 16, 2000 | 12:11 PM
Mr. Peabody's Avatar
New Member
Default Which chip manufacturers are these?
<p>
Rob
2001 2.7T w/everything ... on order :|
smith2010Q7
Q7 MK 1 Discussion
Feb 14, 2016 08:17 AM
Peavey
9
Sep 30, 2009 06:51 PM
USP
Mar 30, 2005 02:35 PM
BSK
Jan 11, 2005 06:14 AM
David P
Mar 28, 1999 12:12 PM
