Remote Range
Old Aug 26, 2000 | 05:26 AM
dba 2.7T's Avatar
New Member
Default Remote Range
I've had my 2000 2.7T (silver/onyx, Tip, cold, convenience, xenon, leather, bose) for two months and I am very pleased with every aspect of the car, but one. Although a minor complaint, the remote does not work if I am more than four parking spaces away from the car.
I realize that limiting the range avoids unintended unlocking of the vehicle as you walk away from it. However, the current range doesn't allow me to lock (or confirm that I have locked) the vehicle from inside my home, which I would find very convenient.
Is this "four parking space range" normal or should it be somewhat greater? Can modifications be made to increase the range? Also, can modifications be made to increase the barely audible beep that confirms the car is locked?
Thanks for you assistance.
Old Aug 26, 2000 | 06:37 AM
SAR's Avatar
SAR
New Member
Default You mean you haven't used your chin antenna?
Sounds strange, I know. Someone on the forum discovered that if you hold your remote up to your chin and press the buttons, the range is greatly increased.
How does it work? Beats me, but it does.
Old Aug 26, 2000 | 09:01 AM
Reto Sommer's Avatar
New Member
Default Better than it used to be...
On my 98 A4 Avant the range was less then 15ft. Now with my A6 2.7T I got a range of about 150ft.
Still not the same as some Americans and Japanese cars but I think this is a minor downside of the car.
silver/black A6 2.7T 6sp PSK-sport and lot's more
Old Aug 26, 2000 | 09:07 AM
New Member
Default If the remote uses radio waves...
you are able to use your chin (bone underneath) as reflector. Should also work with your fore head.
Have fun :-)
Old Aug 26, 2000 | 09:52 AM
dba 2.7T's Avatar
New Member
Default Re: You mean you haven't used your chin antenna?
I thought you were kidding, but I tried it. It worked! Unfortunately, it only added about 5 feet of additional range.
Old Aug 27, 2000 | 06:48 PM
rickinSF's Avatar
New Member
Default Works even better if.....
you lift you left leg 2 inches to change the EMF characture of your body :-) .. actually I am guessing that raising the key higher, is allowing the radio waves to travel better over other parked cars, instead of being blocked by the parked cars metal... just a guess?<p>rick in the SF East Bay
2.7T (on order)
Racing Green / Melange
Prem / Preferred / Nav / Cold / Sunshade
and even the damn analog phone :-)
awdinut
May 29, 2009 07:15 PM
skategoat25
Jun 1, 2003 05:55 AM
dseelye
10
May 11, 2001 02:21 AM
scott928
Aug 30, 2000 01:17 AM
NP
Dec 28, 1999 09:19 AM
