Is there any fuse I can use in the engine room?
Old May 12, 2003 | 01:29 AM
AudiA61.8T's Avatar
New Member
Default Is there any fuse I can use in the engine room?
Recently I would like to install a radar detector which can be hidden behind the bumper. Is there any fuse I can use to provide the power in the engine room?
Old May 12, 2003 | 02:12 AM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default That engine isn't available in the U.S.
So any answer you'd get from us would be a little suspect.
Old May 12, 2003 | 04:34 AM
Edd W's Avatar
Default More a case of engine/car combination......I think that..
the best thing to do is to take a supply from the switched output from the fuse panel that supplies the radio. This will be fine for a Radar detector and will switch on/off with the ignition. You will not need a separate fuse providing you take the feed from the output side of the fuse.
Old May 12, 2003 | 08:01 AM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default That was implied.
I mean, we're on the A6 forum.
radarguy
A6 (C7 Platform) Discussion
Apr 4, 2016 11:47 AM
hoosierchemist
16
Jul 31, 2008 04:49 PM
mcarcane
Oct 30, 2007 03:28 PM
IPsychL2
Mar 4, 2002 06:41 AM
