Is there any fuse I can use in the engine room?
Recently I would like to install a radar detector which can be hidden behind the bumper. Is there any fuse I can use to provide the power in the engine room?
More a case of engine/car combination......I think that..
the best thing to do is to take a supply from the switched output from the fuse panel that supplies the radio. This will be fine for a Radar detector and will switch on/off with the ignition. You will not need a separate fuse providing you take the feed from the output side of the fuse.
radarguy
A6 (C7 Platform) Discussion
04-04-2016 11:47 AM
TTALMS
10-27-2004 05:56 AM
