Is there a way to use the cd changer wires to run a sirius sat. connection
Old Sep 14, 2005 | 12:35 PM
NeedMorePower's Avatar
New Member
Default Is there a way to use the cd changer wires to run a sirius sat. connection
in a symp I hu.
I really don't want fm modulator or a tape connection.
T-Minus 21:25 hours until RS4 Wheels arrive.
Old Sep 14, 2005 | 12:49 PM
TeddyBGame's Avatar
Default Sure...two options...both from BlitzSafe...
Based on the info that you've provided, here is a basic answer:
a trunk version ($70) and one that connects behind the Sym I ($100). The trunk version is cheaper...and easier to install. Of course, you will lose your CD changer in the process (if you have one in the trunk).
It all depends on where you want to mount the tuner and display and antenna. Feel free to do a search on this forum and the audio forum for more pix, posts etc.
See also my sig for my 84 nav+ install pix..so you get an idea what these units look like.
good luck!
-ted
Old Sep 14, 2005 | 12:54 PM
ESN's Avatar
ESN
Elder Member
Default I have a similar connector, RCA plugs right into back of radio, Sirius antenna centered on dash.
no need to wire into cd changer, with the attendant problem of where to put the antenna, and the head recognizes it as the cd changer.
My only complaint is that the line level is lower than it was on the CD changer, so I can't quite blast the Bose the way I once did. Still plenty loud, though.
Old Sep 14, 2005 | 01:17 PM
New Member
Default I just got a quote from crutchfield for $200 that includes
Item Description Ship Qty B/O Qty Price Amount
607ST1 Sirius Starmate ST1 Sirius Satellite Radio/Car Kit Pkg 1 0 79.99
607STH1 Sirius STH1 Starmate Home Kit 1 0 39.99
581DFVW USA Spec Auxiliary Interface Volkswagen 1 0 59.99
581CBPAU USA Spec CBP AU Extension Cable for Audi adaptor PA10VW 1 0 24.99
119RPCHP10 Monster Mini-Jack to Dual RCA 10 foot cable 1 0 24.99
000SIRNFL Sirius Mail In Rebate $30 Coupon for Select Sirius Receivers 1 0 0.00 0.00
000PERIG Crutchfield Guide Peripherals
maudite
Aug 9, 2006 11:10 PM
Berf624
Oct 19, 2003 03:36 PM
CSCOKid
Jun 11, 2003 06:14 PM
ProvGirl22
Audi 100 / A6 (C4 Platform)
10
Nov 2, 2001 11:09 PM
