Cd changer connector
Old Apr 27, 2006 | 06:46 PM
ignazzio's Avatar
New Member
Default Cd changer connector
<center><img src="http://img137.imageshack.us/img137/5492/cdchangerconnector6bs.jpg"></center><p>Couple weeks ago, my cd changer stopped responding, whenever I push "mode" buttom, it would not cahnge to cd mode.
I disconnected the cd changer and found out that one of the pin/contact eroded.
My question is if it is possible to change/replace only the connector not the whole wire? If it is, does anyone know where could I get one? If it is not, could anyone suggest me what other alternatives I have?
Thank You
Link for additional picture:<ul><li><a href="http://img235.imageshack.us/img235/3919/cdchanger0013rh.jpg">http://img235.imageshack.us/img235/3919/cdchanger0013rh.jpg</a</li></ul>
Old Apr 27, 2006 | 06:53 PM
donp's Avatar
Default You can get the body cable from the dealer. The part on the changer, no. But...
You should find out how you're getting water in there... that should NOT be getting wet.
Old Apr 27, 2006 | 11:21 PM
Wood's Avatar
Default It is called a 13 pin DIN connector
(male)
You should be able to find this at any better electronic supply store (I don't think Radio Shack has them). I bought mine locally from vetco electronics.<ul><li><a href="http://shop.vetcosurplus.com/catalog/product_info.php?cPath=72_220_228&amp;products_id= 6573">http://shop.vetcosurplus.com/catalog/product_info.php?cPath=72_220_228&amp;products_id= 6573</a</li></ul>
Old Apr 28, 2006 | 04:04 AM
absolutcq20v's Avatar
Is that a completely eroded pin? If so, wow!
Old Apr 28, 2006 | 04:35 AM
Boston Driver's Avatar
AudiWorld Expert
Default 2nd on the moisture concern. I cannot think of a reason why water/moisture would collect there...
definitely find out that first, then worry about the connector.
Old Apr 28, 2006 | 09:24 AM
OneEyedJack's Avatar
Default Same thing happened on to my 99 A6
Turned out to be a clogged sunroof drain which caused water to drain behind the c-pillar and down onto the CD changer.
Look for water spots on the c-pillar fabric. BTW, I purchased a phatnoise system for $120.00 and spliced into the cd changer cable in lieu of plugging in the adapter cable. This 'fixed' my CD changer issue.
Old Apr 28, 2006 | 05:18 PM
GBW's Avatar
GBW
Default Rubber gasket for cable going to fog light?
On my car I had water on the Phat box. I found that the rubber gasket to seal the hole on the driver rear fender was out of place. The electrical cable to the fog/license lights goes through it. Putting the rubber gasket back in place fixed the problem. It's near the trunk hinge.
brunnhizzle
Dec 22, 2008 06:05 PM
Phat_Rims
Audi A3 / S3 / RS 3
13
Jun 23, 2004 01:31 PM
Lito
22
May 22, 2003 08:45 AM
k4ls
9
Feb 11, 2002 06:33 AM
Ego
Jan 9, 2002 06:12 PM
