Boiling Point
Old Jul 30, 2007 | 05:46 PM
RedRoon's Avatar
New Member
Default Boiling Point
Why does my car keep randomly misfiring? I took my car into Redmond European to get fixed on Friday. New Spark plugs and a coil pack. Later that day it started to randomly misfire. Yesterday it didn't misfire at all and then today the car all of the sudden just started misfiring continuously and the service light now is blinking. I've only had the car for two weeks... have other people had similar problems?
Old Jul 30, 2007 | 07:43 PM
LuvnhatemyA6's Avatar
Member
Classic failure is ignition control module. Need to take it to dealer and get codes read.
Old Jul 31, 2007 | 04:01 AM
4Driver4's Avatar
Tech Guru
Tech Guru
That depends on the year and engine.
Old Jul 31, 2007 | 06:05 AM
OOOOya's Avatar
Default Wrong Plugs?
A couple years ago I replaced the plugs and suddenly had a misfire. I pulled the plugs to compare with the old ones and found one plug that was not the same (right box, wrong plug inside).
Fortunately, I got ahold of the right unit before doing any further ignition system damage.
Old Jul 31, 2007 | 07:11 AM
S4_Cinci (I S'edTFA)'s Avatar
Member
Default The ICM's are located on top of the airbox - high temps could be causing intermittent failure. The
reason these are located on the airbox is so they can be kept somewhat cooler than the ambient underhood. They are bolted to a heat sink and if the heat transfer gets fouled, that could be causing the trouble - or they are simply going bad but haven't totally failed yet. They just malfunction when they get hot enough.
Old Jul 31, 2007 | 10:16 AM
Whitjr's Avatar
I wondered about that, too. Did you have this prob before you had the work done?
Brozee
Dec 30, 2017 07:52 AM
$500
Dec 3, 2006 03:57 PM
boehm781
Jul 27, 2005 09:13 PM
AudiIndy97
Jun 3, 2004 03:23 PM
DrewP
Aug 13, 2002 01:07 PM
