Need help with a vacuum diaphragm part
Old Jan 15, 2009 | 04:03 PM
spoon2000's Avatar
Default Need help with a vacuum diaphragm part
<center><img src="http://pictureposter.audiworld.com/66527/p1000544.jpg"></center><p>On my 2000 4.2, there are a pair of small vacuum diaphragms at the front of the engine. They're connected by short black plastic rods to spring-loaded arms that pivot 90 degrees. I presume these have something to do with controling engine airflow at various operating temps and conditions. See the attached picture at http://pictureposter.audiworld.com/66527/p1000544.jpg
The lower/driver's side diaphragm has been stuck in the sucked-in position for over a year. I was able to push the spring-loaded arm back into position (i.e. make the diaphragm relax), but later the diaphragm would get stuck sucked in again. Around the time that the problem first existed, the car would rev very hard for a minute or two immediately after winter cold starts, then it would run OK.
This winter, however, the cold revving hasn't happened, and today when I looked at the engine, I realized that the black plastic connecting arm had broken. The spring loaded arm had relaxed (as if the diaphragm was relaxed).
What does this diaphragm do? Is there any harm in just leaving it dysfunctional and letting the pivoting arm stay relaxed full time (the other diaphragm seems to work fine)?
FWIW the car seems to spew a notable amount of smelly exhaust on start up...
Thanks.
Old Jan 15, 2009 | 04:56 PM
RLG's Avatar
RLG
Default I think someone machined some alu arms a while back... STFA might help
I wouldn't know the best search terms to use, though.
If you end up needing any new parts to replace anything in that picture, let me know. I've got spares, used but perfect working order...
Old Jan 15, 2009 | 05:05 PM
tozoM8's Avatar
Tech Guru
Default That's your variable intake runner. Here is your fix.
<ul><li><a href="https://forums.audiworld.com/a8/msgs/179821.phtml">https://forums.audiworld.com/a8/msgs/179821.phtml</a</li></ul>
Old Jan 15, 2009 | 11:50 PM
Stampy's Avatar
Default At 4K the arms switch over to the short length intake runner...
It is kind of a common issue for the 4.2. That being said, a lot of people don't even know they have one or both broken. So knowing that...its apparently doesn't really have an effect on anything other than your hp. If you STFA on here you will find a thread about a guy losing 30hp on an S6 because these were broken. They do serve a purpose, just a bad design by audi. I had the same problem, my passenger side was seized as well. I was able to work it loose and got some arms made by a guy here on AW. They are top notch, and won't break. Email me if you want his info.
<a href="http://photobucket.com" target="_blank"><img src="http://img.photobucket.com/albums/v431/stampy616/DSC00232.jpg" border="0" alt="Photobucket"></a>
Old Jan 15, 2009 | 11:59 PM
spoon2000's Avatar
What would cause the diaphragm to seize in the sucked-in position? Thanks for the responses so far.
Old Jan 16, 2009 | 12:23 AM
Stampy's Avatar
Unless the tension on the arm is pulling the diaphram, it will stay "sucked in" at idle/off
Old Jan 16, 2009 | 04:36 AM
A8CT's Avatar
Default They sieze up, do a search on "intake runners" on the D2 board. A couple of us have fixed them.
My theory is that the arms don't break for no reason. If they're broken, it's because they have been snapped in 1/2.
Bob
Old Jan 16, 2009 | 07:00 PM
SteveKen's Avatar
Default I homebuilt steel ones for my S6. Link Inside
Email me for details.<ul><li><a href="https://forums.audiworld.com/a6/msgs/808596.phtml">Link to pics</a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 19, 2009 | 02:48 PM
RLG's Avatar
RLG
Ah! The exact post I was thinking of. Didn't realize it was you, Steve! nice work.
sasikals26
A4 (B8 Platform) Discussion
13
Oct 14, 2018 12:44 PM
mioja
Q7 MK 1 Discussion
Sep 6, 2013 04:18 PM
US_A6_to_EU
30v V6 Discussion
Oct 1, 2010 05:19 AM
MontanA4
Feb 13, 2005 06:12 AM
lauk0dg
Jan 14, 2004 02:12 PM
