Window problem, can anyone help?
START WITH THE WINDOW DOWN>>>>>>
Spray it along the channels and use a rag wrapped around a medium flat blade screwdriver.
Dirt that accumulates in the channels causes a ton of drag. My windows were at the point where I needed to pull up on the glass while a friend hit the window switch to close them.
The method I used above solved the problem.
I am convinced that a little PM on the channels would help solve the broken window guides.
My A6 is a 2001 w /107K-- original guides!
