HELP!! CAR WON'T START
Old Oct 25, 2003 | 04:25 PM
michaelellisa8's Avatar
New Member
Default HELP!! CAR WON'T START
I have a 2000 A8 with 70,000 miles. I live in manhattan and use only on weekends. In any cae, the car wouldn't start today after sitting idle for a week! Do I need a new battery? If so, how much do they cost? Woulds appreciate your help. Thanks.
Old Oct 25, 2003 | 05:46 PM
LenVOS8's Avatar
Default Re: HELP!! CAR WON'T START
Have you tried jumping the battery or charging it?
If it often sits awhile, with out a trickle charger it may well be the Battery.
Old Oct 25, 2003 | 06:34 PM
New Member
I jumped the battery and it started but this is obviously a short term fix. How do I charge it? What is a trickle charger?
Old Oct 25, 2003 | 07:04 PM
LenVOS8's Avatar
A trickle charger continuously feeds a small charge to the battery when parked. Of course you will need to be parked in a garage that can set you up with electricity. Battary Tender is the one I use for my motorcycle because it will detect when it is fully charged and shut off so it doesn't overcharge the Battery.
IF the Battery is the original and it regularly sits without being stated you may need to get a new Battery as the drain down-start-drain down cycle is hard on a battery.
Good Luck
Old Oct 26, 2003 | 02:30 AM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default Check the electrolyte level
If the level is good, you should consider a new battery.
If the level is low, add distilled water, put a good charge on the battery, and try the trickle charger. You may still need a battery, but it's worth a shot.
I think there might be some info on non-Audi batteries, either in Audipages or via searching this forum, once they get search working again after the recent crash.
Old Oct 26, 2003 | 05:22 AM
New Member
Muchas Gracias!
Old Oct 26, 2003 | 06:27 AM
Jkay's Avatar
Default "Battery people" say an auto battery 3yrs or older is on borrowed time. Easy enough to fix.
Get a new one .. if your battery is so shot that it wont hold a charge for the 5 days you dont use it, then it's definitely time for a new one. Dont wait till winter and see how sorry that old battery will be in the cold.
Ulilbastrd
S4 (B8 Platform) Discussion
Jun 6, 2014 12:51 PM
cpbetts
34
Jan 13, 2012 03:07 AM
jeffry
Mar 16, 2011 10:47 AM
sdaman88
Sep 29, 2004 02:59 AM
RNO.Audi
Jun 23, 2003 03:51 PM
