ABS issue ?
Old Oct 12, 2005 | 03:00 PM
A8CT's Avatar
Default ABS issue ?
Ok, I'm reposting since my posts over the past few days turned into my own blog.
Problem is a fairly loud "clicking" in the drivers side caliper area. I'm now able to hear it in park with my foot on the brake. No codes, no light on the dash. ABS seems to be working ok. Cleaned the sensors twice.
If I put my hand around the caliper, I can feel something that matches the sound. Any ideas on what else to try ? First time wishin' for a code to appear !!
Bob
Old Oct 12, 2005 | 04:04 PM
roughyear's Avatar
are u certain the brake pads have enough lining on them.. could be metal smacking metal
Old Oct 12, 2005 | 04:18 PM
A8CT's Avatar
Default yes, they only have about 5k miles on them. This happens when standing still, brake depressed...
so the pads are stationary at that point. It will do it when driving too. A couple of people have replaced ABS pumps. Is this one of the symptoms ? I've never had to do any ABS trouble shooting before aside from the sensors.
Old Oct 12, 2005 | 04:57 PM
tozoM8's Avatar
Tech Guru
Try it with the ignition off to make sure it is not ABS related.
Old Oct 12, 2005 | 06:29 PM
gondar's Avatar
Member
Default Dam*d odd, Watson..
Clicking while static is very odd.
Pull the wheel and see if it still clicks, if so you should be able to put your hand on the caliper and feel exactly where. Could you possibly have a cracked disc or a separation in the internal vent castings? Give the disc a few light taps with a hammer and see if it sounds dead (might be hard to tell with the pads damping it).
Caliper sliding OK? Brake hose secure at all points? And when in doubt, bleed
Be sure and say when you figure this out.
Old Oct 13, 2005 | 03:40 PM
A8CT's Avatar
only with the ignition on.....
Old Oct 13, 2005 | 04:18 PM
tozoM8's Avatar
Tech Guru
So it is not mechanical fault.
Old Oct 14, 2005 | 04:14 AM
A8CT's Avatar
mechanical as in pads/rotors ? agreed, it's something to do with the ABS
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 14, 2005 | 04:47 AM
tozoM8's Avatar
Tech Guru
I would try to unplug the ABS and start the car. I will trow you a code, but you can clear it later.
Old Oct 14, 2005 | 05:10 AM
A8CT's Avatar
good idea. I'll try it at that wheel first and see what happens.
Mike Yates
Mar 7, 2019 02:24 AM
Mike55123
Jun 21, 2007 12:52 PM
Jax
Jun 20, 2006 08:17 AM
teddylove
Nov 2, 2005 08:54 AM
jkaudia8
Sep 28, 2005 05:42 AM
