Injector duty cycle
P.S. The blip in the air flow at low RPMs is the manifold downstream of the throttle filling with air once the throttle is opened wide.
One way to check if this is true would be to physically measure the duty cycle (time open divided by time closed) and compare it to the post processing done by the software. I "think" the rule of thumb is not to operate injectors past 80% duty cycle. I wonder if the reason for that is that the output isn't linear past the 80% mark.
As far as linearity, the ideal is regulation of the injection pressure referenced to manifold pressure. In actuality there are pressure pulses in both the manifold & fuel rail that are a function of the operating point. In addition this was an acceleration run, manifold fuel storage is transient. The ECU is programmed to take this into account.
