With a aftermarket intake like LLtek, does it defeat the purpose if you put the intake box back on..
Old Jun 29, 2001 | 06:11 AM
MAC225's Avatar
New Member
Default With a aftermarket intake like LLtek, does it defeat the purpose if you put the intake box back on..
if you dont like the wooshing sound?
Old Jun 29, 2001 | 06:30 AM
DavesTT's Avatar
New Member
No - actually it will help with blocking the heat.
Old Jun 29, 2001 | 06:35 AM
AMULETT's Avatar
New Member
are you talking about using stock box instead of the heatshield?
Old Jun 29, 2001 | 06:38 AM
MAC225's Avatar
New Member
Would putting the stock airbox back on over the new intake take away from the perform. of the intake
Old Jun 29, 2001 | 06:48 AM
DavesTT's Avatar
New Member
Default It might...
I have the Neuspeed intake. It comes with a heatshield, I think the LLtek does as well. Im not sure how you would fit the box over the intake with the heatshield in place. If you have to remove the heatshield to do it (which I dont think you can, it acts as the mounting bracket) - it may be not worth it. As far is the amount of air that is taken in, im not sure if the box would restrict it in any way.
In short - if you dont like the sound of an intake I wouldn't bother installing one. In my opinion the performance increase is negligible.
Old Jun 29, 2001 | 08:34 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default No.....lid does not seal the intake assembly.....>>
<center><img src="http://pictureposter.audiworld.com/13940/lltekintake3.t.jpg"></center><p>The lid simply serves to direct the incoming air from the fender vent, and possibly reduce the intake of hot air pooled under the hood. There is plenty of open intake area into the filter chamber so no need to worry....I'm working on an insulated cover for this syatem that will further improve the intake charge temp...stay tuned.
Old Jun 29, 2001 | 08:39 AM
AMULETT's Avatar
New Member
How did you get it to fit in so nicely?
Old Jun 29, 2001 | 05:45 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default See the screw in the front left corner!!
<center><img src="http://pictureposter.audiworld.com/13940/lltekintake3.jpg"></center><p>
 Pouria Savadkouei
 Michael S. Palmer
CircuitTested
S4 (B8 Platform) Discussion
Jul 7, 2011 06:30 AM
fushstick
Jul 31, 2004 08:11 AM
EBblack1.8t
Feb 23, 2004 03:49 PM
ChrisTTiaan
10
May 22, 2002 06:13 AM
TTschwing
37
Jul 3, 2001 09:17 AM
