18" wheels on a TT.....
Old Jan 8, 2002 | 08:53 AM
LENELSA's Avatar
New Member
Default 18" wheels on a TT.....
Is there any change in speedometer readings or odometer putting 18's on the TT ?
And, how wide can one go with tires without making steering a problem ?? I have a 2002 TTC and am ready to modify !!!!!!!
Old Jan 8, 2002 | 08:57 AM
TTeleven's Avatar
go with 225/40/18 's and the OD will remain the same as the 17" rim and tire
Old Jan 8, 2002 | 08:58 AM
TTQ2k2's Avatar
Default not if done right
not if you maintain the original diameter--up the the wheel size but decrease the tire aspect ratio..40s versus 45 series.
Old Jan 8, 2002 | 09:16 AM
Bahookie's Avatar
I'm thinking of going with 235/40/18 - will that be a significant change to the O/D ?
Old Jan 8, 2002 | 09:23 AM
raVen's Avatar
Member
Default Here's a good tire/wheel calculator. I use the compare tire A w/ tire B feature alot.
<ul><li><a href="http://www.dakota-truck.net/TIRECALC/tirecalc.html">http://www.dakota-truck.net/TIRECALC/tirecalc.html</a</li></ul>
Old Jan 8, 2002 | 09:31 AM
MichaelTT's Avatar
Senior Member
Default Much more important issue in rolling diameter...messing up the ABS/ESP systems...
diameter should be within + or - 3% of OEM...remember the ABS/ESP systems use sensors at the wheel hubs that measure rotational speed and this info is mixed with tranny output shaft speed and engine rpms...mess with wheel rotation input and will send systems into default or worse.
Old Jan 8, 2002 | 09:35 AM
Bahookie's Avatar
Thanks! Very cool tool.
Old Jan 8, 2002 | 09:46 AM
raVen's Avatar
Member
Your welcome! Us Goldie dad's have to help each other out you know.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 8, 2002 | 01:10 PM
MAX@edgeracing.com's Avatar
Member
Default The best tire match is 225/40ZR18 but many here are using 235/40zr18
Let me know if i can help you with anything found at our website
MAX
800-489-5353 ext 203
MAX@edgeracing.com<ul><li><a href="http://www.edgeracing.com">http://www.edgeracing.com</a</li></ul>
Old Jan 8, 2002 | 02:17 PM
MichaelTT's Avatar
Senior Member
That is what I have...235/40 18 S03s..work fine
TTurner
Wheels & Tires Discussion
Feb 25, 2004 09:28 AM
orangeTT
Jun 13, 2001 08:19 AM
TTEBERTT
Feb 8, 2001 04:38 PM
ttal8
Nov 16, 2000 03:15 PM
mbtt
Oct 26, 2000 10:19 AM
