tire diameter
tire diameter
I'm considering getting larger wheesls and tires. The factory 17" with the bridgestone RE040's have a diameter of 25 inches. I was thinking about getting an 18" wheel with tires that are size 235/40x18. This would increase the diameter to 25.4 inches. Has anyone increased the tire diameter? Has anyone had any problems with rubbing and the bigger tires? Thanks for the info!
235/40/18 is fine, but if you want to ask more questions also check out the wheel forum
<ul><li><a href="https://www.audiworld.com/forum/m.new/wheel">https://www.audiworld.com/forum/m.new/wheel</a</li></ul>
OK, this might be a dumb question but, if you increase the diameter...
do you also have to recalibrate the speedometer? How do you go about doing that?
I have 225/40/18 on my 18" wheels. I would consider going to the larger diameter just for the slight (I don't know how much) decrease in ride harshness.
You want to go to 19" whls? I think you have it backwards, if you increase wheel diameter, but...
decrease the aspect ratio of the tire, from say 40% to 35%, you decrease the amount of rubber between the wheel and the road, thereby *increasing* the harshness of the ride.
No squirm room.
No squirm room.
Go here, I know it says Miata, but it calculates tire sizes & speedo errors correctly.
<ul><li><a href="http://www.miata.net/garage/tirecalc.html">http://www.miata.net/garage/tirecalc.html</a</li></ul>
drew patten
Mid Atlantic Discussion
17
12-05-2007 03:45 PM
A4 Boy Wonder
05-07-2004 01:25 PM
Liam in Montreal
Wheels & Tires Discussion
05-08-2001 12:54 PM
