18" wheels on a TT.....
Is there any change in speedometer readings or odometer putting 18's on the TT ?
And, how wide can one go with tires without making steering a problem ?? I have a 2002 TTC and am ready to modify !!!!!!!
Here's a good tire/wheel calculator. I use the compare tire A w/ tire B feature alot.
<ul><li><a href="http://www.dakota-truck.net/TIRECALC/tirecalc.html">http://www.dakota-truck.net/TIRECALC/tirecalc.html</a</li></ul>
Much more important issue in rolling diameter...messing up the ABS/ESP systems...
diameter should be within + or - 3% of OEM...remember the ABS/ESP systems use sensors at the wheel hubs that measure rotational speed and this info is mixed with tranny output shaft speed and engine rpms...mess with wheel rotation input and will send systems into default or worse.
The best tire match is 225/40ZR18 but many here are using 235/40zr18
Let me know if i can help you with anything found at our website
MAX
800-489-5353 ext 203
MAX@edgeracing.com<ul><li><a href="http://www.edgeracing.com">http://www.edgeracing.com</a</li></ul>
MAX
TTEBERTT
02-08-2001 04:38 PM
