Samco tip HELP!! 5mm hex bolt to turbo..how to remove?
Old Apr 21, 2006 | 04:08 PM
jimmyTT01's Avatar
Old Apr 21, 2006 | 04:14 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default 225? It's a 7mm...>>
You have to remove the strut brace or turbo out pipe depending on how fat your arms are. Bear hug the motor and go down from the top with your left hand, a stubby ratchet and a 7mm socket....You'll have to work largely by feel on this..
Old Apr 21, 2006 | 04:18 PM
jimmyTT01's Avatar
180Q...i thought it was a 5mm??
Old Apr 21, 2006 | 04:23 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Sorry...No idea on the 180...
Old Apr 21, 2006 | 10:52 PM
McTTR's Avatar
Default I used 2 part epoxy to glue a socket to the tbolt. I think 7mm ...
I had attached a series of articulated socket "knuckles" to get a little length and angle on the tbolt. I used electrical tape to ensure none of these would come apart while the glue set or while I was apply torque with a long handle side winding ratchet.
Becareful when you are hugging your engine that you don't put too much weight on your fuel rail or connections.
Give'm hell man.
Old Apr 22, 2006 | 06:44 AM
RoberTT-WWCD's Avatar
Default If you are referring to the cap screw that attaches the cast TIP to the turbo...>>
it's 6mm.
Remove the rubber inlet pipe first then you can get to the cap screw. I used a allen socket and universal adapter to remove it.
Also you will have to bend slightly the oil hose to make room for the Samco.
Instruction and pics here<ul><li><a href="http://public.fotki.com/RoberTT/tt_mods/samco_turbo_inlet_hose/">Samco install...</a></li></ul>
Old Apr 22, 2006 | 06:54 AM
jimmyTT01's Avatar
I will start with what a PITA that was..but well worth it. Thanks for the help
TwentyValveB5+S4
Jun 9, 2006 11:40 AM
Hal_TT::CBP
9
Oct 19, 2005 04:43 PM
FinickyDriver
Jun 27, 2005 03:22 PM
S4iscool
12
Mar 23, 2004 10:56 AM
denic992-- JAYHAWK
10
Nov 5, 2003 09:08 PM
