I don't know exactly how to search the forum for this problem, but...
Old Aug 8, 2006 | 11:34 AM
jman649916's Avatar
Default I don't know exactly how to search the forum for this problem, but...
I was driving home a little while ago and all of a sudden, all my gauges dropped to zero, I lost throttle response, the radio and a/c cut off, and then it all came back on, fluttered for a second, dropped off again, then everything was fine. Then it drove perfect on the way back home. The entire episode lasted total about 4 seconds. I had thought it may have something to do with the connections coming from the battery (since it was relocated a few weeks ago), but even if the battery came disconnected, the alternator would still charge it, and vice versa. So I can't see how the whole system could be seeing a huge drop, unless the computer itself is just cutting in and out. Has anyone else had this problem before?
Old Aug 8, 2006 | 11:44 AM
JustJeff's Avatar
Default If you indeed have relocated the battery, check *all* those connections. An alternator alone will
not keep the car running.
Check your cables, battery posts, battery manifold connectors, fusable links, etc.
if you did mnot use a battery terminal cleaner, do it now.
Remember: disconnect the NEGATIVE cable first.
Difficult to believe its the ECU, but possible.
nightdancer420
2.7T V6 Discussion
Feb 11, 2015 02:42 PM
myers1.8TQ
Sep 16, 2008 10:54 AM
Par
Nov 29, 2007 08:32 AM
y'allroad
Audi allroad
Nov 24, 2007 07:28 PM
SnowZach
Nov 14, 2003 06:39 AM
