Car Stalling Out!
Old Jun 22, 2007 | 04:12 AM
MEBurr37's Avatar
New Member
Default Car Stalling Out!
I have an 04' 225QC. I've brought it to the dealership 5 times now for the same problem. Every morning after having it sit all night the car stalls out on the first attempt to start it. After it stalls once, it starts up fine on the second attempt. So far the dealership has replaced: Temp. sensor, Throttle body, Fuel press. reg. switch, Mass airflow sensor, Fuel pump/Fuel filter. The problem is still occuring and I have no idea what it could be, neither does the dealership. ANY SUGGESTIONS WOULD BE HELPFUL!!!
Old Jun 22, 2007 | 04:19 AM
InTTruder's Avatar
AudiWorld Awesome User
Default can you get a VAG on ot before starting and check codes.
I suspect a vacuum problem.
Old Jun 22, 2007 | 05:35 AM
Rocky-in-Connecticut's Avatar
Default mine does that every once in a while
no idea what causes it. When doing my recent TB R&R I checked as many vacuum lines as I could while the car was apart. The line to the combi valve looked a little baked so I replaced it. I have not had it stall upon startup since but I have only been driving it a few days since the TB replacement. So we'll see.
I also scan w/ Vag Com every few weeks and there have been no codes.
MEBurr37's Avatar
New Member
The dealership claimed there are no codes being listed.
Old Jun 22, 2007 | 05:58 AM
InTTruder's Avatar
Have they 'observed' the behavior, or just the car as-found when you delvier it to them?
Old Jun 22, 2007 | 06:10 AM
oc_tt's Avatar
Do you turn the key to ON and get the OK! before cranking?
Old Jun 22, 2007 | 09:06 AM
MEBurr37's Avatar
New Member
The OK always goes on when it is clearly not OK. And yes, dealership has been observing it
Old Jun 22, 2007 | 10:10 AM
Scenic Driver's Avatar
Default The reason he asked this is because many have had this problem >>>
Waiting the extra few seconds seemed to fix it for some, probably has to do with building up fuel pressure.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 22, 2007 | 10:12 AM
InTTruder's Avatar
Try waiting after the OK a few seconds. Your FPR may be a bit slow with age, but still funtional.
Old Jun 22, 2007 | 04:28 PM
gyTT's Avatar
Default Re: Have they 'observed' the behavior, or just the car as-found when you delvier it to them?
your dealer lied to you. I same problem as you before. Brought to my dealer, the problem is the battery. They refill the acid water and tighten the cable.
Did you pay for anything?
prijedor
A4 (B7 Platform) Discussion
Apr 19, 2018 06:24 PM
Dissious2005
2.0T FSI Discussion
May 26, 2011 03:07 PM
bcacly
Feb 11, 2005 02:14 PM
Audi200T5000S
Apr 2, 2003 12:47 PM
SteveAngry
Misc. Models Discussion
May 8, 2000 10:42 AM
