after run coolant pump
Old Feb 19, 2008 | 03:59 PM
First and Goal's Avatar
New Member
Default after run coolant pump
01 225: my after run coolant pump is not working. Any ideas on where to start? Is it always the coolant pump that goes or should I look elsewhere first?
also, thanks to all those who contribute to the FAQ page.
Old Feb 19, 2008 | 04:16 PM
rumburak's Avatar
most the time it's the pump that bites the dust.
Old Feb 19, 2008 | 04:20 PM
JohnLZ7W's Avatar
Default just replaced mine using SparTTan's writeup in the FAQ
Very easy repair. Mine had started making death rattle noises.
Old Feb 20, 2008 | 11:23 AM
TTest-D3MON's Avatar
Default hows the AC and the radiator fans?
I had a bad fuse connection in the box on the top of the battery, and my after run coolant pump, AC compressor, and radiator fans stopped working. I would definately notice the other two not working first in Texas, but if its cold enough where you are, you might not have. So check those, cause it could be as simple as a rusty fuse bottom.
davidj2006
Sep 26, 2008 04:03 PM
Jaster
Oct 3, 2007 06:18 AM
2000audis4ny
Feb 27, 2007 11:58 AM
TTransport
Aug 27, 2006 11:51 AM
TTS_4_to_A6
9
Dec 12, 2001 10:19 AM
