What is the equivalent to 8.5" wide ET35 wheel w/ 15MM spacers...
Old Feb 23, 2008 | 09:00 PM
ePuFFy's Avatar
Default What is the equivalent to 8.5" wide ET35 wheel w/ 15MM spacers...
but in a 9.5" wheel?
Wondering if a 19x9.5 wheel would work...
hope that makes sense...
Old Feb 23, 2008 | 09:19 PM
Russ Scott's Avatar
Default Several folks run 9.5's on the back
and at least one fool's running 10's!
offset depends on variables
like the poke?
prefer the tuck?
shocks got external reservoirs?
etc...
et 35's a good place to start, 8.5 with 15mm spacers put you at et 20... might stick out a bit
9.5 without a spacer is very close to 8.5 with 15mm.. 8.5/spacer sticks out further, but only 1/16+
Old Feb 23, 2008 | 09:34 PM
meem's Avatar
Elder Member
Default if the offset is the same and the width is increased by an inch ...
then half an inch has been added to both the inside and outside. so you need to remove half an inch (12.5mm) of spacer -- thus you'd need a 3mm spacer.
Old Feb 24, 2008 | 02:11 AM
elf888's Avatar
Default Re: What is the equivalent to 8.5" wide ET35 wheel w/ 15MM spacers...
Dang... where can I get a wheel like that? Does it come in black?
tomaszp72
Q5/SQ5 MKI (8R) Discussion
43
Apr 19, 2016 06:37 AM
SUBLIME
9
Mar 2, 2006 12:08 PM
TimD
Apr 11, 2004 08:29 AM
kam123
Audi allroad
Aug 19, 2003 04:29 PM
