Question about after run turbo coolant pump------>
Does anyone know more? There has to be a relay somewhere. I suspect mine is failing.
TIA guys
Other model Audis (some non-turbo's have an after run pump too, my A6 with the 2.8l has one) have used temp sensors to try to determine more precise run time, but I understand they're less reliable than our set up. IIRC the fan control module is in charge of the after run pump. Nine times out of 10, intermittent and/or complete failure of the pump is remedied by replacing the pump. I'm on #3 pump, averaging 70k miles of useful life per pump. My original fan control module is still going.
Picked a fine time, as I ran the heck out of my car at Barber this weekend. I started looking because I smelled antifreeze when I parked after my last couple of runs. I fear the hot turbo with no after run pump may have cooked the hose where it connects. Hope the seals are ok.
